onetwenty8k
- Nov 24, 2006
I want to possibly revamp my computer. The main things I am looking for is to lower power consumption and run cooler, less heat output. I will list what I currently have. Please tell me what I should keep for the new build and what should go.
-Some gaming. L4D, TF2, GTA:SA. I play at 1920x1200 resolution.
Cheap as possible.
3) Where do you live?
NJ
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
6) Will you be overclocking?
Yes, I love to overclock, this is a must.
Dell 2407FPW
Now.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
No extra features, standard. Though I want it to be a stable motherboard.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes.
Now that you have that, here is what I am currently running.
Case: Lian-Li PC-60B (I could go for a new case though)
Optical: Samsung DVD+-RW SATA
HDDs: 300GB Maxtor Drive, 320GB Seagate drive: Both SATA
Motherboard: Gigabyte P35-DS3L Rev 2.0
CPU: Intel E2160 @ 3.0Ghz Stock VCore
Graphics: eVGA 8800GTS 320MB
Sound: Creative SB Audigy 2 ZS
RAM: 4GB OCZ PC2 6400 (I think it's that speed)
Tell me if I left something out. Thank you very much and I look forward to your help.
An extra note. I am not at all opposed to the idea of a Micro ATX build.
Cheap as possible.
NJ
Dell 2407FPW
Now.
Yes.
