lower end C2D vs higher end C2D for OC.
HaxEJxuK
I always had question about this but never really bothered to ask. Let's say I have e6300 and e6700 and OCed both to 3.3GHz. Is there any difference between them in number crunching and gaming besides 2MB less cache? I mean I know it makes little difference with extra cache but besides that any difference? I checked spec and only difference I could find was clock speed and L2 cache. How about e2140 at 3.3GHz? If I don't take difference of cache, are there and difference?
You are exactly correct, no difference but the cache size. In fact if you look up the Intel data sheet you will see it covers the whole family.
So take any C2D, clock it to the same speed on the same system and if you were running something that did not use or bypassed the cache or could turn it off, they would all perform the same. (with tiny differences in heat produced based on the "luck of the draw" die quality. )
I will add, and it is just speculation on my part, it seems to me that Intel is speed binning a little tighter than at launch and probally has several production lines, all using the same basic process. They all still OC very well and it is rare to find a "dud". But it is not quite like it was a launch when probally every single cpu core came off the same line, speed bins where just to confirm it would meet whatever spec they needed at the moment. All speculation but it makes sense and is standard practice (speaking from experience now) that once you get the line up and running smoothly, you start looking for ways to make more money out of it.
The good news is apparently they hit the bulls eye and Intel finds it difficult to make a crappy Core 2 duo. I do not think they were quite ready for how well it worked from a marketing standpoint (back to speculation). It appears with the new 45nm Penryn's that Intel has made the mulitpliers work in such a way that it will not be as easy to buy a low end and exceed the performace of a stock high end part, but I am still reading up on them.
(egads ! They may be on to us :D )
Only thing that is sure about O.C. is that nothing is assured...it's a lottery pick anytime...even if Intel has been generous with the prices ;)
Thanks for clearing that up. I thought that was the case but I was never sure. I know L2 cache makes difference but not enough to spend extra couple of hundred $$$ for very minimal increase of performance.
yes the difference is in the cache and the bigger the cache the faster FPS in games.
theres a site diccuss about it and compare all of it in gaming world.
so
e2140 = > goes to oc 3.6ghz same with e6600 oc at 3 ghz
