- Oct 29, 2000
Hey all,
I'm prepping a Mini-ITX Hackintosh build for my GF's birthday.
I usually build things big, so low profile coolers are something I'm not that familiar with.
I think I have settled on the 54W Haswell Core i3-4330.
The case I have gone with says that max compatible cooler height is 80mm.
The Noctua NH-L12 is 92mm with both fans installed, and 66mm with only the bottom fan, so if I got it, I'd probably be restricted to the bottom fan only, unless I find a super thin 14mm 120mm fan for the top.
I've also looked at the Noctua NH-L9i, which is much lower profile, but I ahven't been able to find any comparisons between the two, where the NH-L12 is run with bottom fan only. I wonder which would perform better in that configuration.
Any other good low profile coolers I should be aware of? This is a relatively low power system which won't be overclocked, so silence is probably a higher priority than temps.
Much Obliged,
Matt
Much Obliged,
Matt
