Low power server for data storage, file sharing, streaming video to PS3, computer backups.
Trying to keep it around $600 but I am flexible.
3) Where do you live?
Western Pennsylvania
Motherboard
CPU
RAM
Hard drives
Power supply
Possibly case, haven't decided if I will reuse a case I have
OS License
I probably will reuse a case I have. Also, I will be temporarily borrowing a DVD-rw drive from another machine for the initial install.
6) Will you be overclocking?
No
I will not have a monitor attached to the computer.
Roughly 1-3 months. I'm not in a big hurry.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Minimum of 4 SATA ports to allow for future expansion.
1Gbps LAN (I'm assuming this is standard these days).
Wake on Lan is preferred, but not required.
No, I will need to purchase WHS if I decide to use it over FreeNAS.
I am planning on building a low cost/low power server. I am currently considering WHS or FreeNAS, but I am currently leaning towards WHS. I don't have large data storage requirements. Right now I have 3 computers and the combined hard drive capacity between them is less than 1 TB.
I don't have specifics in mind regarding hardware.
Motherboard/CPU - Considering Gigabyte D525 mini itx http://www.newegg.com/Product/Product.aspx?Item=N82E16813128452
RAM - 2 or 4 GB - not sure if 4GB is needed
Hard drives - 2x2TB hard drives
Case - Doesn't really matter as it will be located out of sight.
Power supplies - Don't know much about power supplies or how many watts would be needed for it.
Motherboard
CPU
RAM
Hard drives
Power supply
OS License
No
