New here! Seeking advice for a completely new PC build.
1) What will you be doing with this PC?
Gaming, will be mostly Starcraft 2. Some Photoshop use as well.
~$600 preferably with tax/shipping included.
3) Where do you live?
San Francisco, CA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Literally "everything". Have no parts to re-use.
CPU, motherboard, case, power supply, RAM, hard drive, optical drive, video card, network card, sound card. Maybe a media reader/hub but not necessary.
None
6) Will you be overclocking?
No
Have a 24" monitor already
Now/anytime soon in the future.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
No requirements. But would prefer the option for future upgrades if it does not drive the cost up too much.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes, Windows 7 64-bit
I would really prefer an Intel build, but I know AMD is the cheaper/budget friendly route. I am open to options.
Thanks for any help!
San Francisco, CA
None
No
