Hi folks,
I'm thinking about putting my spare time to better use by learning to play the piano. There's a problem with this cunning plan, however. I don't have a piano, nor do I have room for one even if I went out and bought one.
I'm thinking of getting a simple midi controller keyboard to use with my PC. I'd put it on my computer desk, and listen to myself playing using the headphones I use with my PC. This has the added benefit of making sure that others aren't distracted by the sound of me practising like they would be if I were playing a real piano.
I don't want to spend too much money given that I'm only just starting and have no idea if I will get fed up with it after a few weeks. I intend to keep at it, but I don't want to spend too much money in case I change my mind. From my initial googling it seems like some of these devices can be very expensive, and the cost comes from build quality, pro-musician features (which I don't care about, I'm literally only interested in using the keyboard keys) and the kind of "key action" used.
I'm looking to spend £50-£100 (though I'm slightly reluctant about the higher end of that range since I don't know how much use I am going to get out of this purchase). It seems like, in this price bracket, the key action is always velocity based rather than something more "real-piano-like". A few models I've looked at initially are:
M-Audio Keyrig 49
http://www.maudio.co.uk/products/en_gb/KeyRig49.html
I can find it for a little over £50 in online shops. Perhaps it is a bit "too" cheap, in terms of how the keys feel in use (and perhaps in general build quality)? Though I kind of like the fact that it isn't covered in bells and whistles. I don't need fancy functions that a pro musician might use.
E-MU Xboard 49
http://www.emu.com/products/product.asp?category=532&subcategory=533&product=13558
Seems to be right around the £100 mark. The reason I noticed it is because it seems to be reputed to have a very nice key action in its price bracket. It also seems to have other fancy functions that I don't care about though. The price is right on the limit of what I'd be willing to consider so I'm wondering if it is worthwhile for my uses.
Behringer UMX61
http://www.behringer.com/EN/Products/UMX61.aspx
I think I can just squeeze a 61-key version on my desk, and this one's under £100. Not sure about build quality and key action though.
Any advice or ideas? Am I completely barking up the wrong tree here?
(Apologies if this post is slightly outside the remit of this forum, searching didn't bring up much similar discussion)
M-Audio Keyrig 49
E-MU Xboard 49
Behringer UMX61
