I'm about to start scanning thousands (and thousands ...) of 35 mm slides. With the batch loader, I can do 50 slides at a time. Each slide scan will take several minutes and I will do each scan batch overnight, so transaction speed is not really an issue.
I want to use a dedicated system as the "controller" for scanning, because there is simply no room in my regular work area for the scanner, the boxes of slides to be scanned, and the space needed for cleaning slides before scanning them.
System requirements for the scanning software are pretty minimal.
Can anyone recommend a low-cost motherboard, CPU for this system? My preference is for an ASUS motherboard, but I'm open to other brands. I would also want at least 2 SATA ports, 2 USB ports, and Ethernet.
Thanks in advance.
- Windows XP, Vista, Windows 7, 8
- 2 GHz Processor or faster (Multi-core recommended)
- 2 GB RAM main memory (4 GB RAM recommended)
Thanks in advance.
