Low Budget Build (MSI P45)
CAR8624
I’ve been doing research for hours (and loving it). However I may need your help/advice on finishing. I may be doing the “impossible” but my friend wants to get into competitive gaming and future gaming (specifically CS 1.6). However my friend is on a limited budget [and he may actually have to buy in parts] – what I mean about limited, I mean very limited (aiming below $500 at max $600). He will eventually buy better parts in the future, but I want him to get the ball rolling.
AIM:
-Low budget gaming for CS 1.6 (for now) with option for good Overclocking (Good Mobo)
-Low budget EVGA card so he has an option for Step-Up program to EVGA 8800GT as end result
Now for the parts (Note: Everything from Newegg/prices except for GPU since it needs to be from a qualified site for Step-Up Program):
Motherboard: GIGABYTE P43 GA-EP43-DS3L ($94.99) vs. MSI P45 Neo3-FR ($119.99)
-I was debating whether to go for Gigabyte or MSI but Gigabyte does not have RAID option. I’m not sure if my friend will ever go for RAID, but paying $25 more for the option shouldn’t be painful. It’s lovely that both Mobo support PCI Express 2.0; do you think I should go for P35/cheaper Mobo?
-Both should be great for OC – don’t you think? Been lurking on the forums too much. Credit to Danny for posting.
-Technically for this system build, the motherboard is the most expensive because I have a leeway of upgrade other parts [instead of replacing the board itself + finding compatibility].
CPU: Intel Pentium E2180 (2.0GHz) ($69.99)
-Since he is not doing hardcore gaming right away, this CPU technically should be more than enough for CS 1.6 (and Web Browsing). This CPU is compatible with MSI’s (have not checked with Gigabyte – but I’m sure it is). For now, I am suggesting he use the stock HSF.
RAM: Corsair 2GB (2x 1GB Sticks) – DDR2 800 ($47.50)
-Again, he’s on a low budget and I’m not sure if there’s a big difference between 800 and 1066. He will eventually buy much better RAM (with much better Speed).
HD: Western Digital 160GB SATA 3.0 ($43.99)
-More than enough for XP + one or two games. He won’t be downloading, and if he is he can buy a DVD Burner or buy a larger HD in the future.
PSU: Thermaltake 430W ($34.99)
-Not sure how good the PSU, but I have a Thermaltake 700W and hasn’t given me problems. I’ve checked the 12V and it should be enough for the future 8800GT no? I admit if the PSU is terrible (haven’t done quite a good amount of research here) – but he only needs a PSU to supply the future 8800GT, few HDs + 1x Optical Drive, CPU and Mobo. Enlighten me if you found something better with good value.
-If you’ve noticed I have not included MIR – after he gets his MIR he will use the refund for future parts.
For GPU, the EVGA 8600GT should be enough for him to run CS 1.6 smoothly. He is going to purchase from another site (less than $100) that is qualified for Step-Up Program. IMO – do you think it’s worth the Step-Up Program or get a much better card?
As for case, I was debating on getting him the “most inexpensive” case (Rosewill) – but I know many posters will argue to spend a little more for value. From the specs I listed above, is it worth it?
Cost [without GPU/Case]: $316.46
-I will find out prices for GPU later on since it’s on a different website.
-This will be shipped to New York (damn taxes) – anyway to avoid NY taxes? I’m just dreaming.
In the future:
GPU: EVGA 8800GT (either Superclocked or Stocked – doesn’t matter)
CPU: OC E2180 or get him E8400.
RAM: 2 GB should be enough, but maybe much faster speed (1066)
PSU: To support more HDs/Optical Drives – do you think this is necessary?
HSF: I’ve heard great things about Xigmatek – is that great for OC?
Case: Eventually we will find a better case for him unless the $20 is worth it heh.
Mobo: Plan on keeping this for a while.
Any suggestions will be helpful. I know that having a low-budget build is crazy, but I tried =p
The MSI P45 neo3-FR has a $20 rebate right now and I think through the end of July. So, assuming the rebate materializes, it is only $5 more than the other board you were considering.
I would spend a little more on the hard drive and get a 500 GB Seagate drive from frys.com for $80. It's 3X the capacity and comes with a 5 year warranty for about 2X the price. But if he can't afford it, then he can't.
I don't have comments on the rest, as I am not an up to date gamer.
Mobo: Don't bother with a P35 motherboard at this point in time. They're roughly the same prices as P45 motherboards but don't have PCI-E 2.0 which might be useful in the future. So best err on the side of caution and go with the P45.
Theoritcally, the MSI motherboard should OC a little bit better than the Gigabyte motherboard due to it's better cooling on the northbridge. With that said, the Gigabyte motherboard's cooling is sufficient for overclocking with the E2180. Just stick a small fan on it if there's any OC limitations or problems.
I'll go more in depth over your build list later. Got a class now. :)
That TT PSU is garbage, 18A on the 12V line is not enough for an 8800GT. Take a look at the following instead:
Antec NSK6580 w/ EA430W PSU $90
Antec Sonata III w/EA500W PSU $100
Those are nice cases and come with quality PSUs that can handle what you are planning. I would go for the Sonata given the small price difference betwen the two. As well, skip the EVGA 8600GT. To step up you have to pay the difference between your cost and MSRP of an EVGA 8800GT which is completely not worth it these days. Try and get your friend a PNY 9600GT for $99 at CC or a 4850 if that fits in the budget.
Well ToasterOven has saved me some typing. :D Follow his advice as well.
In addition to what he said, if you can't get in on the $100 9600GT, you could still pick up this card for $100:
ASUS EN9600GSO GeForce 9600 GSO 512MB PCI-E Video Card - $100
Also you don't faster RAM, even with overclocking in mind. C2D CPUs do not benefit from having faster RAM outside of overclocking. So DDR2 800 RAM is all that you need for the E2180 for stock and overclocking. Some math:
Stated FSB/4 = Actual FSB
Multiplier x Actual FSB = CPU Speed
1:1 Ratio: 2 x Actual FSB = RAM Speed
1:1 Ratio: FSB = 1/2 RAM speed
E2180:
Multi x Actual FSB, RAM Speed = Clock Speed
10 × 200Mhz = 2.0Ghz, DDR2-400 <<== Stock speeds
10 × 266Mhz = 2.6Ghz, DDR2-533 <<== Easy OC
10 × 333Mhz = 3.3Ghz, DDR2-667 <<== Good OC
I'd say get a 4850. Step up has disadvantages as they inflate the msrp price making any kind of savings null.
I don't know if they will rerun the special, nor if the OP has a Frys near them, but the case mentioned above was $55 at Frys about a month ago. Frys does tend to rerun the same specials over and over, much of the time.
I was shopping for a case and PS at the time, and the NSK6580 with EA430W was actually cheaper than buying the EA430W by itself. Although, later I saw that Newegg had the EA430W for less than $40 after rebate.
As it turned out, about six feet down the case aisle, Frys had the Antec P-180 on sale for $75 and there was one left, so I snagged that and the True Power Trio 550 they also had on sale for $40. It was about twice the cost of the NSK6580, but a very nice setup.
I knew the PSU was terrible. So Ill consider getting the case + PSU. But from the reviews, Case + PSU isn't the way to go - is that true?
E2180:
Thx for the input; P35 isn't worth it unless you already have one.
For HD, 500GB is much better for value/price but he's on a tight budget.
Generally Case/PSU combos are a bad thing since the included PSU is usually shit. But not so in this case. Antec case/PSU combos do come with decent PSUs. The EA500 and EA430 are both Seasonic made and have been shown to be good PSUs. So it is a good idea to go with certain Antec case/PSU combos.
I totally agree with this one. I bought a sonata III last October. The PSU is great. I liked the case a lot. It is very well laid out case and looks great. But I just wanted something with a lot more room (and I got a bonus), so I picked up a Cosmos in June. However, I kept the power supply because it really is that good.
I traded the case with a friend for a case of beer. I think it was a good deal. :)
So, I say save some money on the case/PSU, get a sonata III and get a 500GB hard drive and 4GB of ram. 4GB is really worth it right now for vista64.
