- Oct 7, 2000
wirte down the xmp settings you want and then manually enter then. if it still not stable try bumping the ram voltage a bit. all ram can handle +10%v without a prob.CPU: Ryzen 5 2600x
PSU: Corsair CX550
MB: Msi x470 Gaming Pro (mod bios v14)
GPU: Asus Turbo Gtx1070 8gb
RAM: Patriot 4 dual channel kit 2x8gb rated at 3200mhz (but cant get it stable that is why i am asking for help)
Hi Guys Found this Thread and i had to register to seek for help.
It looks like all of you had a very intensive tweak and testing so probably you could help me to tweak my system.
With the mod bios F6 Load Default and select profile 2 XMP (the 3200mhz profile) seems to boot (not always) but when it does it will Blue screen as soon as i try memory test (is use MemoryTest 5 v12 pattern by 1usmus).
If i Select XMP profile 1 (the 2933mz) seems all ok, and actually if i use the "Memory Try" with lower timing (14-16-16-16- 34 // 69-382 1T) it is holding with no errors
I am trying to use the Dram Calculator but i do not know how to input all the numbers in the modded bios
some number are not present or are not numbers but combination of number and letters instead
for examble instead of lets say 16 clk i have numbers and h i cant remember now i need to see the bios.
anyway even if i do this changes it seems not to work and i need to "loose" timing but this is what i dont know how to do. can you guys help me to try tweaking this ram?? so annoying is not working Stock
and also if i export my bios profile can i share it here with you and can be edited for exaple with notepad++
so i can re import it if you can edit it for me, so i can at least see what you have changed?
Thank You in advance to who will help me.
