Loud Hardware Beep when Backspacing in empty input field (Win XP)
Discussion in 'Operating Systems' started by Stormlifter, Oct 28, 2007.
  1. Stormlifter
    Stormlifter 2[H]4U
    2,968
    Oct 19, 2002
    I'm not sure what is doing this, I have a sound card and it works, I'm listening to Flogging Molly right now, but when I backspace into an empty input field my computer emits a lard hardware beep, as in it sounds like that beep that you get when your desktop boots up, only louder.
    Anyone have a clue? I have a Dell E1705 and Windows XP Media Center
  2. SockMan!
    SockMan! 2[H]4U
    2,187
    Jul 31, 2004
    Download the the TweakUI powertoy from Microsoft and disable "beep on errors" from the general settings.
    Windows has an annoying tendency of beeping at you if you set set the Windows sound scheme to 'no sound' (or if you have no soundcard installed).
  3. zacdl
    zacdl [H]ard|Gawd
    2,012
    Feb 12, 2007
    ... or if you don't have the drivers installed.
  4. Stormlifter
    Stormlifter 2[H]4U
    2,968
    Oct 19, 2002
    I applied the change and I'm still beeping.
  5. SockMan!
    SockMan! 2[H]4U
    2,187
    Jul 31, 2004
    I was going to suggest disconnecting the internal speaker since it's not used except for diagnosing startup problems, but then I noticed that you've got a laptop...
    Do the beeps happen regardless of what software you're using? Or is there a particular piece of software that beeps?
  6. PenaltyShot
    PenaltyShot Gawd
    964
    Sep 4, 2002
    How about this:
    Start -- Run --Regedit.
    Go to Registry Key: HKEY_CURRENT_USER\Control Panel\Sound
    Find "Beep" regkey
    Set it to 0 (Disabled)
    Exit Registry and Reboot
  7. PenaltyShot
    PenaltyShot Gawd
    964
    Sep 4, 2002
    On second thought, I'm not sure if that controls hardware beeps as opposed to system beeps coming out of the sound card (like "ding" and "chord" and those types). Might be worth a try anyway, I dunno.
  8. Stormlifter
    Stormlifter 2[H]4U
    2,968
    Oct 19, 2002
    I have noticed that it is mostly Pidgin (formerly Gaim)
  9. Stormlifter
    Stormlifter 2[H]4U
    2,968
    Oct 19, 2002
    Mine is currently set to "No"
  10. tazman4
    tazman4 Limp Gawd
    233
    May 6, 2005
    Which is it?
    According to your title, it happens when you backspace in an empty field, but then you say it happens when you backspace into an empty field.
    Since I've never been able to backspace into an empty field (must usualy shift+tab), I'll assume your title is correct.
    Most every machine I've ever been on does this, although not in all applications. It's trying to tell you that the field is indeed empty & you can't backspace any farther.
  11. Stormlifter
    Stormlifter 2[H]4U
    2,968
    Oct 19, 2002
    how do i disable that? that's what I want to know.
  12. PenaltyShot
    PenaltyShot Gawd
    964
    Sep 4, 2002
  13. shadowwyvern
    shadowwyvern Gawd
    604
    Sep 22, 2005
    My thinkpad used to do this, or something similar. First look in BIOS for an option to disable, then look in the device manager for a device called beep (I beleive it is hidden). This might be thinkpad specific though. Here is a page with some more detailed instructions.
  14. Stormlifter
    Stormlifter 2[H]4U
    2,968
    Oct 19, 2002
  15. PenaltyShot
    PenaltyShot Gawd
    964
    Sep 4, 2002
    Well, no, actually it was just talking about disabling the system beep and mentions that in this particular case it was occurring on a pop-up. The person describes it as the same beep as the one you get from the post (describing the sound of it) -- not that it was happening at post. So I took the solution as being for disabling the system beep wherever it may happen. Although maybe you're right that the solution only addresses a post beep, 'cause it has the word "Start" in there (as in, the post startup beep?). Hmm...dunno, sorry. Thought it might be worth a try.
  16. TheGamerZ
    TheGamerZ [H]ardness Supreme
    5,218
    Sep 18, 2003
    That system beep only happens to me when I'm using Pidgin on XP and backspace an empty IM window. Nothing else causes it for me.
  17. Stormlifter
    Stormlifter 2[H]4U
    2,968
    Oct 19, 2002
    We have the same problem! Any luck with fixing it?
  18. TheGamerZ
    5,218
    Sep 18, 2003
    Didn't look for a solution. Just don't backspace when there's nothing to backspace :p
    It was on my mom's computer, which I'm only on once a week when I visit, so it's not a real big deal for me.
  19. JaYp146
    JaYp146 [H]ardness Supreme
    5,548
    Apr 24, 2005
    The same thing happens to me, and it's bloody annoying.
    Has anyone found a fix for this yet?
