Ok, while swapping out my MB, I noticed I have a loose wire on my 24 pin connector. It is a small orange wire that was bent so the area of pin 1, 2 and 13 side. Anyone have a Seasonic power supply that can look to see which pin it actually goes to?
For reference pin 3 has a small black wire going into it with the other normal wire. So I assume the orange is the same.
Any tips for getting the pin out? I have the CaseArts Molex tools but can't seem to get the PSU one to go on both sides of the pins.
