- Sep 27, 2005
- Primarily for photo editing (Lightroom, Photoshop, with additional other photo editing software). Might get into HD video editing (this is something I haven't experimented enough with, but given an option I'd like to be able to do it comfortably).
- Gaming. Nothing too fancy, Starcraft 2, Diablo, Witcher... some newer titles I haven't heard of yet.
- $1500-$2000 (shipping and tax included)
- IL, USA
- Case, and everything that goes inside the case. CPU + HSF, RAM, Mobo, PSU, Video card, cables, sound card, DVD/Blu drive(s), fans.
FWIW, I like the look of Lian Li PC-9F case.
- Monitor, speakers, mouse, keyboard
- I do have an ATI 6870 which is adequate for whatever gaming I do now. Could possibly reuse that as well.
6) Will you be overclocking?
- No
- 24" @ 1920x1200 (but the monitor is due for upgrade, possibly larger with larger resolution - separate budget).
- Planing on doing it this or possibly next month.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
- USB 3.0
- W7 Ultimate 64bit.
- IL, USA
- No
- USB 3.0
