I am a computer science student, so I use my desktop for coding (Java, C++, ect.) and I also like to play FPS games.
Looking to spend around 800 dollars all in.
I am located in Central NJ thankfully I can drive to a Microcenter.
This is where I am struggling I know for $800 I can't really do a total rebuild, but am looking to do a refresh. Definitely looking to upgrade my graphics and not really sure where else I can find some more performance.
Here is my current set up.
Gigabyte Z68X-UD3H-B3
Intel 2500k running at 4.5ghz with an Kühler H2O 620
16gb (4x4gb) G.SKILL Ripjaws X Series
2x EVGA GTX 560 1gb VRAM in SLI
I have a couple of Samsung 830 SSDs (256gb [Windows Drive] 64gb[Linux Drive])
A couple of Seagate HDDs for storage.
Asus Xonar Sound Card
A pair of Optical Drive a Lite-On Blu Ray Player and ASUS DVD Burner
6) Will you be overclocking?
Yes
I have a 29in AOC 21:9 monitor running at 2560x1080
This week or next week definitely before Christmas
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
E-Sata, RAID, SLI, USB 3.0
Yes I have a key for Windows 7 Pro 64 Bit, and Windows 8.1 64 Bit although I think I will be keeping this machine on Win 7.
Basically I'm just looking for the best way to increase my performance. I definitely want to upgrade my graphics to something more powerful. I'm just not sure if I should also get a new Mobo and Processor or maybe just put an Ivy Bridge i7 with Hyper Threading in my current Mobo. I guess I should also state that I really prefer Nvidia over AMD, so I know that will hurt my already tight budget, but its just my preference.
Thanks in advance for all of your suggestions.
Yes
