Looking for some build advice
Oldie
Mean Old Administrator
Hey guys, first off, here's the Q&A:
Gaming, photoshop, and encoding some hd video will be the more intensive tasks
I have a very open budget for this, I can spend whatever I want for the most part. I'd like to keep this under $1K, but it's not a big deal if I go over.
3) Where do you live?
Midwest US
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, RAM, Mobo, SSD, Video Card
PCP&C 750 Silencer Quad, but will upgrade if needed. Case, 2x 1TB Drives, X-Fi Platinum
6) Will you be overclocking?
Maybe a little, going to be focusing more on keeping the rig quiet.
For right now 3x Dell 2007fp S-IPS panels, may move to 3x24 with this setup later.
Probably ordering no later than the 12th.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
e-sata is a plus, don't care about raid, would like firewire, and crossfire is a possibility I would like to keep open.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Win7 x64 Ultimate
Here's what I've got picked out so far:
I7-920 Bloomfield LGA1366
OCZ 3x2GB 1600 (OCZ3G1600LV6GK)
A 5850, probably an XFX
Intel X25 80GB
I'm bascially looking for the best bang for the buck I can get on a reasonable powerful rig. I don't need insane speeds, not trying to compete just want something that will handle some basic encoding and provide a decent gaming experience. I will be using eyefinity quite a bit (and yes I know I need a DP adapter, already budgeted). I don't need to run every game full on, and w/20 Inch screens I'm sure the 5850 will do well. If I go to 24's later, I'll be upgrading the video card at the same time.
That said, I haven't really researched for a rig in awhile, and wouldn't mind some feedback from you fine folks if you're willing. I might do some mild oc'ing just for kick here and there, but I'd rather keep the system reasonably quiet than faster.
I've looked at several mainboards, and I'm wanting one that supports x-fire and SLI, and where the PCI slots are positioned where it won't create a problem for the x-fi.
Any recommendations?
Check out this mobo:
$230 - Asus P6T Intel X58 ATX Motherboard
There's enough clearance for two double slot video cards in the PCI-E slots and a PCI sound card .
Do you live next to a frys or microcenter?
Fry's is about 2 hours, if I'm in that direction I might stop in. I'm seriously not that worried about price, I just don't like wasting money for no good reason. ;)
It's definitely on my short list, but I've heard some people were having e-sata issues in Windows 7, and frankly Asus's craptastic website and driver support left a bit of a bad taste in my mouth. Their quality/service is good though, so they're not off my list. I've got a P5B Deluxe right now.
Gotcha.
Here are a few other mobos that has a similar layout to the Asus mobo I recommended above:
$190 - MSI X58 Pro-E Intel X58 ATX Motherboard
$270 - EVGA E758-TR 132-BL-E758-TR Intel X58 ATX Motherboard
$285 - EVGA E758-TR 132-BL-E758-A1 Intel X58 ATX Motherboard
I'll check those out man, thanks. :)
