- Apr 22, 2002
What does everyone recommend? my budget is between 200-350. I just need something for school work, with decent battery life, and maybe able to play a low end game like doom or warcraft 3 every now and then.
If you want a 13" screen, don't get anything with an atom in it(processor...lol) get the Dell v13. I hope to have mine on the 2nd, I am so excited!I have been looking for sometime for a Light weight Netbook/Laptop. And in the end i drew the conclusion that its useless to get Netbook. I will agree with the above comment that ULV is the way to go. Check sites like tigerdirect has some pretty low weight laptops (refurbished) for around 400$ or less. Also get 13.3 inch screen, it will have better res and good view. There is though one Atom based MSI x320 going around for about 390 or so @ eBay and few one other Online store, that can be a good choice over 10.1 screen.
I am very interested in the new ULV dual cores coming out from Toshiba and HP but they cost over 500$. SO do check out the Atom based MSI x320 has 13.3 screen and decent specs.
Anyways, even though it is clocked at 1.3Ghz, the front side bus is much faster, and you will notice it. And, at $449, and only .65" think, its a steal!
I recommend the Asus 1005pe, 14 hours of battery life! Looks stylish too.
