Looking for inexpensive Motherboard
Karama
I am building a second computer from spare parts. I have an old 2.4C Proc and so I am looking for an inexpensive motherboard. I am looking at the ASUS P4S800D-X and was wanting some feedback. This box will be used just to do large encoding and decoding projects. Will be doing Video and Audio projects. I just need something so that I can set it and go instead of my main computer being bogged down with these projects. Going to use a KVM switch to just switch over set it and forget it. Stability is more important than speed. Any help would be great
does the S series use the SiS chipset? if it does, dont get it.
i have an abit IS7-E that i got off the forums for 50 bucks, or the E2 retail at newegg, ZZF, and chiefvalue is about 70 shipped.
Yea, it's SiS, which makes me nervous but for the price you get dual channel memory. The closest intel chipset with dual channel is $95 vs $60 for the P4S800D-X.
For value, I like the MSI PT880 Neo-FISR. Check out the [H]ardOCP review here. I linked to the conclusion page, but feel free to check out the rest. You can run dual channel on it, and you can get it for $63.99 Shipped 2nd day at Zipzoomfly here.. I've installed two of these and I got a good 500mhz OC on one and a 450 on the other w/some questionable ram and stock cooling. Definitley a good value.
That particular ASUS board has a SiS chipset (as opposed to the similarly labeled one with the budget Intel 848 chipset).
The 655TX chipset was supposed to be comparable to the 875P. It overclocked pretty well, but not as high as the 865/875 series. That board has the 655FX chipset and it wasn't as good as the TX. ASUS made a board based on the 655TX called the P4S800 Deluxe which was supposed to be pretty nice. Almost got one myself.
