Basically, I want to run multiple high-rpm scythes and 200mm fans, and quite honestly one fan header from my motherboard doesn't seem sturdy enough to do (for some reason, only sys_fan1 is working under voltage control, sys_fan2 is pwm I believe and sys_fan3 doesn't seem to control anything).
I found the Bitfenix Recon, NZXT Sentry 2 and Sunbeam Theta.
I just want simple automatic control. I can live with a single thermocouple (on the CPU), maybe a second one on the GPU. I do not need multiple profiles, just one that ramps up say when the CPU gets above 40°C. I do not need fancy controls, in fact I don't even want one in a 5.25 bay. I liked the Theta a lot because it uses a PCI slot, and one that uses the PCI-e slot would work as well.
The Bitfenix Recon seems to match this the most. I don't think the Sentry 2 does automatic control (correct me if I'm wrong). Are there any other alternatives? I also prefer one that doesn't cost over $50.
