Max-Powers
- Jan 9, 2005
I will be using this computer as a HTPC and gaming machine. Gaming on 1080p LCD TV. Because gaming requires more power than HTPC, if I can game, the HTPC aspect only requires some outputs like spdif and HDMI, a TV tuner, and I should be good on HTPC hardware. I just want to make sure there is no problem gaming using this setup on 1080p.
I will never play crysis!! Fallout 3, Left 4 Dead, orange box, CnC and such. My main concerns are noise, heat, and will it fit in my case. I will be sitting 6'' away and am not too picky.
My budget is ~$1000 but I can go over without it hurting my feelings.
3) Where do you live?
Austin TX 78717
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything including TV tuner which I will choose at a later time. Still looking.
6) Will you be overclocking?
I do not plan on overclocking.
I plan to have a 42''+ LCD TV at 1080p
I will build it in July
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
No crossfire. I want good onboard sound. I want Firewire and spdif
10) Do you already have a legit and reusable/transferable OS key/license?
I have a Vista. The basic Vista that would come with a dell computer. I hear the 32 bit Vista only supports 3.5 gig of RAM. Is this true? If so, I will need to buy Vista 64.
As I explained above, I want a gaming rig that I will also use as a HTPC in of course a HTPC case. Here is what I have so far. I am going with an intel build.
Case: LC20B-M
Or the Antec Fusion Remote Max. With the LC20 I will have to buy the case fans which I don't mind. Has good reviews and should suite my needs if everything fits. One question is, what are some good 80mm case fans? The Remote Max is big enough and has great reviews, but it is just so huge.
Motherboard: GIGABYTE GA-EP45-UD3R
I chose this mobo because it had many ports and seemed to get decent ratings. Onboard sound will be going to a Denon 1909 and then to a Energy speaker setup.
CPU: E7500
This is dual core. The quad core is just too expensive and I am not going to hardcore game.
CPU Cooling: Noctua NH-U9B
No real reason why I picked this one. It was suggested to me. I wont overclock so all I need is something that is quiet and can move air around.
Video Card: GIGABYTE Radeon HD 4850 1GB
This is passively cooled. I want it to be quiet. I am willing to change my choice on this if I can be convinced. I dont want anything faster. My concern with this is if it will fit in my case. I will also need air to move around within the case fairly well. I don't do hardcore gaming, so it shouldn't get too hot. Had good reviews from what I have read.
Memory: some OCZ Reapers 2x 2gig (4 gig)
Clueless here. I know nothing about memory. Picked these because I hear OCZ is great and this one had the little award thing next to it =) But The little scythe bullcrap looking thing worries me. Why is it there? Will it mess up anything? Will it stick up too much? I can just go with whatever; OCZ had some purdy
Power Supply: CORSAIR CMPSU-650TX 650W
I hear crosair has great power supplies. This one had a nice rebate and good reviews.
Anyway, what do you think? Any suggestions to exchanging parts?
Austin TX 78717
Case: LC20B-M
CPU: E7500
