looking for a system burn in test tool
chronic9
going to buy a whole PC from a user on this forum. I would like to know if theres anything wrong with this system before I buy it. Preferably a free tool :)
Memtest of course, along with Orthos [dual-core] or prime95 [quadcore] depending on what CPU it is.
Orthos and Prime95 can still run on AMD CPUs.
For HDD tests, HDtune is a good option
I usually loop whatever the latest version of 3DMark is at the time over night, then run 3-4 hours of Orthos, and 6+ hours of Memtest86. If it makes it through that you're good to go.
I just use the Ultimate Boot CD.
Its got most of the tools you need to check a computer out all in one place.
Luck ......... :D
