Looking for a SSD for my HTPC...
Badcop1124
I just lost my my main drive to my HTPC in the East Coast storm the other day.
I want to replace it with a SSD. I was going to order this SSD and was looking for some guidance.
I would like to order from Amazon or the 'egg.
My HTPC set up:
HTPC: Win7 Ultimate 64bit/Abit IX38 QuadGT/ Intel Core 2 Duo E8500 Wolfdale 3.16GHz/ ZALMAN 9500A 92mm/ LITE-ON 4X BD-ROM/ Corsair XMS 4GB (2x2GB) DDR 800/ HIS Radeon 4670 1GB/ WD Caviar Black 750GB x2/ WD 2TB Caviar Green WD20EADS/ CORSAIR CMPSU-450VX 450W/ SILVERSTONE LC13B-E ATX case/ Samsung 46" LCD
Thanks in advance.
go with what? How big were you looking for? How much are you looking to spend?
Yeah, what is "This"? To the OP, am I missing something or did you not include what SSD you were looking at or am I misreading your post?
I corrected my mistake. I didn't link to the SSD in question.
I was only looking to put my OS and some small programs like Media Browser on it.
So I was thinking the 60gb would be plenty big.
I would like to stay around $150.
My HTPC set up:
Okay, while I didn't buy the Vertex line, I DID buy the Agility line. The only real difference is what memory modules go into which line. The performance differences are negligible unless you're truly trying to min-max.
And, just to be stupid about it, I went with TWO of them and RAID-0 (most of my important data is running off a separate drive and I'm running backups just in case).
This is what my Atto bench looks like.
Expect about half of this with a single drive.
A couple things.
Make sure your BIOS is updated as much as possible. I was only a rev or two behind and it wouldn't let me install to the SSDs initially.
Take a good long look at your OS install. 60GB may seem like enough. But my system with all my apps installed and all the Windows Updates slapped in weighed in at around 60GB. Granted, this is WITHOUT cleaning all the patch uninstall files out. But still.
To put it bluntly, you DON'T want to paint yourself into a corner on this. Buy with an eye towards extra headroom just in case. Maybe look at stepping to the 90GB model. Yeah, there's a price hike.
Maybe I'm being too paranoid about this due to my experiences with a bunch of customers who took delivery of Dell servers with 40GB OS partitions a while back only to find out they can no longer apply any updates due to lack of drivespace. Just thinking about it makes my flesh creep (yeah, yeah, that's a LOT of creeping).
Cool. Glad you found what I said useful.
Enjoy.
I use a 30 gb drive in my HTPC and have plenty of free space.
40-50 gb of applications on a "HTPC"? How? What?
With two-three other traditional hard drives available in the same chassis, I don't see why you would need a 90GB, or even 60GB.
I use an Intel 40GB drive in my HTPC. I've been finding them for around $90 lately, plus it's Intel. All of my media is on a server so the only thing I instal is Mediaportal and a few odds and ends. I've got plenty of room. If you don't store your media on the HTPC or record, and just use it as a HTPC, you really don't need much space. Think about how you use your system that should determine how big a drive you need.
If you're playing games on it too you should take large installation requirements into account as well (GTA IV recommends 18GB of space for example). Went with the Corsair Force F120 for my HTPC.
Yeah I've been swooping up 30 GB SSD's. Picked up 2 for my 2 HTPC's. Use it as my OS drive and stream everything from my server. Speed of SSD + Low Cost/Power Efficiency of 2TB Green drives = WIN!
