Looking for a spoon fed single PC on demand backup solution.
narsbars
I want to follow coloring book instructions to make bare metal backups of a single PC, 2 TB drive, and at least one secondary 1tb drive, on Windows 11. AMD based PC X570, 5900, 64 gigs ram. I have a number of external USB backups of varying sizes and don't care about speed. I might be able to stretch the budget to a plug and play for dummies solution software to go with what I have. I would like to simply make a backup, a 2nd a month later, then a third before recycling the 1st backup drive.
Please, this is all about budget and I cannot start building a NAS, tossing my slow backups for multiple NVMEs, or spend hundreds on a "best case" solution. I don't have enough grey cells to spare to follow highly involved solutions so that explains my need for a "Dummies" solution. My ideal is to hear that I should buy X software, or use X software free, connect external drive and push the big green button. By backing up everything I might be able to restore to a replacement PC if needed but at the least I will have everything and not have to choose which files to save and then say OOPS later when trying to retrieve a misfiled doc or keycode.
If day acronis or macrium reflect, I believe they can create a USB bootable media to be able to fully backup your drive
Totally forgot about Macrium after it became pay to play but I can still download the final free version. I will probably break down and buy the lifetime license $80.00. Thanks
Hiren's BootCD has this and other "imaging" tools; this could possibly work for you... (and fits your definition of "all about budget")
he doesnt want imaging he wants automated/on demand backups. yes a paid version might work, but not the hirens one.
acronis or macrium paid are probably the best options, theres also easeus.
Are you saying you want to backup the 2TB drive to a collection of various USB drives, or you want to backup the USB drives to the single 2TB drive?
