Looking for a shuttle type SFF case for Gaming build!
Jboogey
1. What will you be doing with this PC? Gaming, Photoshop (or other intensive programs), Overclocking, Web browsing, strictly HTPC/Playback, etc. (If you have multiple things you want to do with the system, make sure you rank them from most important to least important).
Strictly gaming and web browsing.
2. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
Don't really have a budget, Whatever I choose to do will be done, regardless of funds, might take some time to make though.
3. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
There is a Microcenter a ways away from me and a Frys Electronics close by.
4. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need.
Not exactly looking for help selecting the parts, more need help in selecting a sff case, similar to shuttles or some of the silverstone models i.e. sugo 08. I want to be able to fit a full profile high performance video card like a gtx 660 ti or preferably a AMD 7950 or 70. Also, I'd like to squeeze in a Liquid cooling kit.
5. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
6. What specific features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
USB 3.0, no need for XFIRE or SLI, SATA 6.0 preffered.
7. What resolution output do you need? 1080p, 720p, DVD quality, etc for HTPC or list Vertical/horizontal resolution for non-HTPC SFF rigs. Do you need multiple monitor output?
NONE
8. Does this system need to fit into a particular space? Think entertainment center shelves, closet space, rackmount, etc.
On Top of my desk. No real space constraint just need something that looks aesthetically appealing, and is also performance oriented.
9. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
I'm comfortable doing minor case mods i.e. I don't mind cutting a hole or two to fit case fans.
10. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
Not important, I consider some medium-loud machines to be tolerable as I zone myself out really easily.
11. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
It will be stationary
12. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
Windows 7 64-bit
13. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
Over the next 2-5 months.
Some of the cases I've been looking at and are interested in
Shuttle SZ77R5
COOLER MASTER Elite 120
SILVERSTONE Sugo Series SST-SG08B
I just finished this build using the CM Elite 120, I love the case and it can fit a ton of hardware but it's still such a small footprint and it's freak'n cheap as crap for such a complete case.
Take a look at the build thread to see some good pics of the internal case and get ideas.
Shuttle cases are nice but you limit yourself to their psus, silverstones are nice as well but you'll limit yourself usually on dvd drives (slim, or slim slot loading) and their cases are more expensive and require most of the time an sfx psu which comes at a premium as well.
Lian Li is another brand I would check out - they are slightly pricey and they have very nice internal features, use ATX psu as well as 5.25 bays etc.
Good luck!
buy a falcon northwest tiki. it is one of the best itx cases money can buy, and is so expensive that nobody has one. in my opinion this is the best choice for someone with unlimited funds. falcon northwest makes a fair profit margin on this product, but IMO everything else is pedestrian in comparison.
The new shuttle R5 (standard ITX) formats along with the powerful 500w psu is a powerful combo. Why not go for the shuttle instead of something like it? (I ask that factually, not rhetorically)
SZ77R5 or SX79R5 would be my recommendation.
Easy to work with, nice and small, 600 watt 80+ power supply.
Freakin awesome case and I've yet to see another case like it.
You could just as easily get the SZ68R5 as well. Intel SB 2500K is still one of the best CPUs you can get. Add the ram, hdd, and optical and you are set. I'd opt for the SZ77R5 with an IB CPU however since they run cooler at stock speeds. Make sure you have the latest BIOS however since there has been issues with the earlier Bios. If you are wanting to overclock heavily you may want to consider yanking out the ICE and installing a Asetek 545LC hydro unit instead. It greatly outperforms Shuttle's ICE cooling.
If you want something other than Shuttle, but look similar and want to build your own you could get a SG05/06 or a SG07/08 for itx. You could even get a SG02 for matx. Silverstone makes the cases for Shuttle supposedly so they look similar. Lian-Li also makes some nice small cases as well. Just depends on which form factor you want and how small you want to go.
