Impulse said:Stacker is the only ATX/BTX case out there that I know of... it's fairly large tho. If you want something smaller a CM Praetorian (tho CM is phasing them out for their new ones which will be released soon), a Kingwin KT-424, or one of Lian Li's dozen models will fit the bill.
If it doesn't have to be aluminum Silverstone has some very nice steel-made models (with aluminum bezzels so they still look quite good), the TJ-06 has an interesting design (BTX-like), the TJ-05 I think it is has a more traditional internal design andb curvy bezzel similar to the CM Wavemaster.
starhawk said:
Brando457 said:well whats the reason for the extra 50$ then.......
The_Dark_Hacker said:no open both links side by side. they are the exact same color, model number, item number everything
