Looking for a mobo/cpu for agp / pc3200
Ocean
Well im scavenging up some old parts: and i have a couple of gigs of ddr pc3200 (dual chan matched) and a 7800gs agp, and everything else from that era to build a machine. i can use either sata or pata interfaces.
im just missing a motherboard/cpu combo to use all that stuff. im not looking for most powerful. just best bang for buck.
any suggestions?
This might be your answer:
The AsRock 4CoreDual-VSTA or 4CoreDual-SATA2 supports both AGP and PCI-E, as well as DDR and DDR2. AT did some reviews on that board:
http://www.anandtech.com/showdoc.aspx?i=3024
http://www.anandtech.com/mb/showdoc.aspx?i=2810
http://www.anandtech.com/showdoc.aspx?i=2813
http://www.anandtech.com/showdoc.aspx?i=2814
Summary: The board is a good, budget stopgap solution for people who want to get more life out of their DDR and AGP stuff. DDR400 is still fine for today's applications, and only high end NVIDIA graphics cards will be affected by the 4x speed of the 16x sized pci-e slot, but not by much (PCI-E Scaling Review).
Pair it with an E2160 or E4500 and OC either one to 3Ghz, and you'll be all set!
$70 - Asrock 4CoreDual-SATA2 Socket 775 Via PT880 Pro/PT880 Ultra Chipset DDR2 667Mhz, AGP & PCI-E x16 8-Ch Audio
$70 - Intel Dual-Core E2160 Allendale 1.8GHz 1MB L2 Cache
$120 - Intel Core 2 Duo E4500 Allendale 2.2GHz 2MB L2 Cache
well, shit. that is exactly the type of info i am looking for. speedy too. and from newegg.
ill check a few other things about it, but it seems to be exactly what i would need. i wasnt even expecting the pci-e slot combo.
thank you.
