Looking for a Haswell modular PSU <$100
Om1zzle
Building a new rig and am looking for some guidance on PSUs. Build is as follows:
4670k
GTX 770
8 GB RAM
Samsung 840 Pro 256
2x 7200 RPM HDDs
I'm not looking to spend over $100. I am thinking 600-700w is the sweet spot, but am open to 700+. The quieter the better.
Here are a few I'm looking at:
SeaSonic M12II 650
XFX 650w
Corsair TX650M
Am I barking up the wrong tree here? Do you guys have any other recommendations or commentary?
Nvidia can eat shit. But if you wanna go by what they say over me, that's fine.
A 770 stock will pull around 225w. Cpu will pull 80ish watts. About 50w for everything else, plus alittle overhead brings you out to around 400w.
400w is fine for that system. GPU manufacturers overstate requirements because most people use junk PSUs that can only provide like 80% of their rated power (some even less!).
I recommend the Rosewill Capstone 450w or 550w. I don't recommend Seasonic because they have issues with coil whine, especially at low power states, which Haswell's C7 state will probably make worse. But if you don't get or mind coil whine then Seasonic is in generally also an excellent choice.
