Looking for a good Motherboard
citrusfizz
Hey Guys,
I was hoping someone here could help me out
i need a *micro* motherboard that supports am2 cpu with at least 2 sata slots, pretty decent onboard video, and the onboard video must be able to do tv-out with s-video, must be compliant with ddr2 533 ram and have 6-8 channel audio
is there a all in one motherboard that can fill my needs?
if found different stuff on new egg.. but most of them i couldn't tell if it had tv-out via s-video and thats kind of importannt
thanks
I don't think you're going to find one unless Asus or someone like that makes an S-video bracket for one of their mATX boards. I've seen them before, but it's not "native" on the motherboard like the S-dub or DVI ports.
lol isn't it D-sub?
I agree--you're not going to find s-video as one of the connectors on the I/O shield. On a separate PCI bracket, yes, but not on an I/O shield.
Do you have a special project in mind?
Edit: Whoops, there actually exists such a board!
Yeah, PCI bracket is what i meant :).
Well, there you go...the DFI is what you need :D.
The DFI board is slightly larger than that standard 9.6x9.6 though...just fyi.
Yeah I just noticed that too...looks like almost an inch larger. Probably to get another PCI slot in or something like that. I guess it depends on the case.
sorry for not being more clear
the s-video can be on a pci bracket thats fine.... the audio can be on a pci bracket for all i care i just need a board that i know i am going to get both with
for under 100$ hopefully
the board does need to be 9.6"x9.6" or smaller there are no if ands or butts(big ones)
so what board would be the best for my ealier specs ?
In that case, you'll want to pick up the ASUS M2NPV-VM. Onboard VGA & DVI, Component/S-Vid/composite on the PCI bracket, SPDIF header, 4x SATA, yadayadayada.
If you were willing to stoop to Socket 939, I'd recommend this Jetway board--it has SATA, component/s-video/VGA/DVI, a bunch of sound channels, and it's a heap cheaper than that Asus board above. Oh, and it comes with just about every overclocking feature you could want. I built a machine for my niece on the S754 version of that board, and it's a joy to work with.
