Looking for a good case.
GaleForce
I'm looking for something made of aluminum with a good size window. I don't want fan holes or anything on the top or side because I am watercooling. No premods aside from the window, and no stupid window designs. I find it hard to find this. I could settle with a Lian Li but those are expensive. Right now I am planning on getting a Wavemaster with the windowed side panel, but I am disappointed with the size of the window. Any ideas?
I can only suggest to look all over Newegg and if ya don't find somethin else, get the Lian Li..
KINGWIN All Aluminum 10-Bay Mid tower case
http://www.newegg.com/app/ViewProductDesc.asp?description=11-170-013&depa=1
http://www.newegg.com/app/ViewProductDesc.asp?description=11-170-012&depa=1
Cooler Master Cavalier 3
http://www.newegg.com/app/viewproductdesc.asp?description=11-119-058&DEPA=1
http://www.newegg.com/app/ViewProductDesc.asp?description=11-119-062&depa=1
Personally, I would choose the CM over the KINGWIN for the aesthetics and features alone. But that window etch on the CM may turn you off.
I didn't know you could get wavemasters with side windows, so I got a Thermaltake Tsunami Dreams case. It's pretty good and the only problem with it is that it's a Thermaltake :D and it's a rip-off of the wavemaster, but apart from those two things it's a very good case.
NewEgg doesn't sell the CM WM with the window included, I dunno if other places do... NewEgg does sell the windowed side pannel as an accessory (either silver or black Al, the window can be either clear or blue).
