Looking for a Fan Template
RBall151
I can't find an actual real size fan template anywhere..
I need an 88mm fan template so I can cut a new hole in my case.
Does anyone have a link? A while ago I saw a .zip somewhere...
here
this is a little more than you need, but save it to your computer and you'll always have it when you need it. that's what i did;)
Use the fan. Drill your four bolt holes, draw lines from them corner to corner and *tada* the center for the holesaw
Yeah I wish I would have bought a holesaw drill bit. BUT they are like $35 bucks...what a rip off for only using it like 3 times.
