I am looking for a router now that I have an XBox 360, swapping ethernet cables is getting pretty old. I currently have cable internet via Comcast and am using a Motorola SB5101 modem. I plan on connecting the 360 via ethernet to whatever router I get cause $100 for a wireless adapter is ridiculous and because it sits pretty close to my computer anyway. I've been doing some reading online and I'm under the impression that I need to get a router that has 100mb bandwidth or better. Is that the case and why? Does my internet connection determine or dictate the actual bandwidth that there would be to dispurse via the router? Does this spec even matter since I'll be using an ethernet cable to connect it?
I know with this planned setup that I could go with a wired router but my son is going to be getting a computer in his room pretty soon so I'd like to prevent from having to buy another router when that time comes. His room is about 30ft from my computer, if that matters.
I've heard the 802.11a is the most secure way to go, but the most expensive too. 802.11g seems to be the most common and 802.11n seems to be the future. That being said, I'd imagine "g" would be the way to go, am I wrong for thinking that? Or should I plan for the "n" revolution? One thing to consider is the fact that i'm not an early adopter of technology.
I've been searching for decent routers and am strongly considering these:
Linksys WRT54G2
D-Link WBR-2310
Linksys WRT54GL
Linksys WRT110
Netgear WGR614
Belkin F5D8231-4
Right now I really want the WRT110 (although the Belkin offering is pretty damn sexy) mainly because it matches everything in my computer setup, piano black w/blue led's. Since I know nothing about the specs or what to look for in these things i'm going purely off looks right now. That is something that is important to me so I'd like to preserve the sexy of my computer as much as possible, but not at the cost of performance unless the discrepancy is so minute that it's irrelevant.
I'd like to keep the cost as reasonable as possible so I'd say $80 would be about as much as I'd like to spend for it but I would consider upping that a bit if neccessary.
Linksys WRT54G2
D-Link WBR-2310
Linksys WRT54GL
Linksys WRT110
Netgear WGR614
Belkin F5D8231-4
