looking for a decent motherboard?
machu1
that overclocks good. i have an e4300 1.8ghz and trying to get it up to the max. plz any help which one to pick.
Price range? right now P35 seems to be king as long as you don't need SLI. Good mobos are P5K-e/Deluxe/Premium, DFI DK P35, IP35-Pro, DS3P/DS4 and Neo2-FR just off the top of my head.
Or you ould go with a P965 board if you're on a tighter budget, those should OC that chip just fine.
Like in your other thread, here's a list of mobos I recommend:
Gigabyte GA-EP35-DS3L Intel P35 Motherboard - $90
MSI P35 Neo2-FR Intel P35 Motherboard - $110
DFI BloodIron P35-T2RL Intel P35 Motherboard - $115
Gigabyte GA-EP35-DS3R Intel P35 Motherboard - $120
DFI LanParty DK P35-T2RS Intel P35 Motherboard - $130
Asus P5K-E Intel P35 Motherboard - $140
Gigabyte GA-EP35-DS3P Intel P35 Motherboard - $150
Asus P5K-E/Wifi-AP Intel P35 Motherboard - $150
Abit IP35 Pro Intel P35 Motherboard - $170
Gigabyte GA-EP35-DS4 Intel P35 Motherboard - $170
Gigabyte GA-EX38-DS4 Intel X38 Motherboard - $207
Just to help you out: If you don't need RAID, more than 4 SATA ports and only need semi-decent overclocking, check out the DS3L. If you need 5 SATA ports, 2 eSATA ports, slightly better overclocking, and a second PCI-E x16 port, then get the Neo2-Fr. If you want heavy overclocking options and six SATA ports, check out the Blood Iron. If you like the BloodIron but want significantly better overclock stability and options, go for the LanParty. If you want 8 SATA ports, RAID, legacy ports and high overclocks and optional eSATA, than the DS3R is a good choice. If you want the DS3R but need Firewire and a second PCI-E x16 port, then go for the DS3P. If you like the DS3P but need 3 PCI slots instead of the DS3P's 2 PCI slots and like having non-optional eSATA, go for the Asus P5K-E. If you like the P5K-E but need wifi, then go for the P5K-E/Wifi-AP. If you want something that can overclock pretty damn high along with RAID, eSATA ports and firewire connections, than the IP35 Pro. If you like the DS3P but want better cooling for overclocking, then go for the DS4. Do note that the Asus website can be slow sometimes.
All of those mobos will OC quite nicely with the E4300. Now it's up to you to decide which motherboard has the features YOU want.
Well put...LOL
The E4300 will max out around 3.4Ghz. Even the lowest recommended board, the DS3L, can easily handle such an OC.
/*------------- <cut n paste> -------------*/
Formulas for Intel platform @ 1:1 settings: (base FSB speed is SDR, or single data rate)
c × [Base FSB speed] = CPU Clock speed (c = CPU Multiplier)
2 × [Base FSB speed] = RAM speed (DDR: double data rate)
4 × [Base FSB speed] = Effective FSB speed (QDR: quad data rate)
On Intel platforms, running the RAM higher than a 1:1 ratio with the CPU is, for the most part, useless, so don't bother trying to do so. If the BIOS does it for you, just let it. All you need is a 1:1 config, though. Here's some possible clock speeds (as always with OC'ing, your results will vary):
E4300: 9 × 200 = 1.8Ghz, DDR2-400 << STOCK speeds
E4300: 9 × 266 = 2.4Ghz, DDR2-533 << Simple OC
E4300: 9 × 333 = 3.0Ghz, DDR2-667 << Good OC
E4300: 9 × 400 = 3.6Ghz, DDR2-800 << Nearly Impossible OC
/*------------- </cut n paste> -------------*/
what is this about?i dont get it?
Look at it carefully. That's the math for your E4300. It tells you what RAM you need and what settings you need to get a certain OC with the E4300. You need to understand all of that or you cannot OC well.
oh ok.
well i get it more. well i bought a hp computer and i cant mess with the bios or overclocking it.and i dont know how?
Ok..............and?
You already have the list of recommended motherboards above, the math to get the OC you want, and a guide to show how to OC. If you go with a Gigabyte motherboard, here's a more comprehensive guide on overclocking with Gigabyte motherboards:
http://hardforum.com/showthread.php?t=1169366
oh ok. what is the best for overclocking that you think is the best?
As been stated before, for your CPU, ANY of those motherboard listed will OC about the same with your CPU. The low-end $90 DS3L will OC the E4300 just as well as the $170 Abit IP35 Pro.
ok ill just get the DS3L
i have an abit ab9 pro?that good for overclocking.i had it for a while.i tried to built a custom computer but it didnt seem to work. it would go beep beep beep and turn off.and i never knew why?
Heh, I just RMA'd one of those. It should be good for OC'ing, if you can get it to work.
It sounds like you have A LOT of reading to do. Check out the GenHard FAQ in the General hardware subforum.
ok cool.check it for what?.so im going to put all of the computers new stuff on in and take out the old motherboard asus p5le Leonite-GL8E. what does it mean when it goes beep beep beep and turn off.why?. and it says 8.2 on the code thing on the corner with numbers.ill try to put it all together and see if it works.
