Ohmycaptain
- Jul 10, 2011
I've just got my three 27" Catleap monitors and it turns out my 7970's Active mini DP-DVI adapter, nor the HDMI-DVI adapter works with these.
I can use the DVI port with a DVI cable, but that only gives me the option to use 1 monitor (which is what I'm currently doing).
I can't afford to buy three cards right now, purely because it would require a PSU upgrade and a motherboard upgrade on top of it. So, I need a card with two dual link DVI's so I can run these three monitors off of two cards.
Preferably a 7970 so I don't have to sell mine, but I'm not sure if there are any that aren't 1x dual 1x single?
It must be a GTX 580 or more as far as power goes. I'd definitely prefer a 7970 though because not only do I have one but the advanced eyefinity options on the 7xxx series cards is great to have. Also, scaling is pretty awesome with them in CF.
