Gaming/light programming
around $1300
Kansas
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word
"Everything" is not a valid answer. Please list out all the parts you'll need.
CPU
MoBo
RAM
Case
HDD(SSD)
Cooling
Antec 520W 80+ certified about 3 months old
Zotac 550ti (Hoping to use this in SLI with a better card)
6) Will you be overclocking?
to about 4.5
1440x900 sad I know
Around May or early June after IvyBridge
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
SLI would be nice
Nope
This is my current build. Remember I'm just looking at information as to what I can improve on. This build will be with the ivy bridge equivalent of the i5-2500k
CASE: HAF 912
CPU: Ivy Bridge i5
GPU: GTX 680(Huge overkill but will upgrade visual in following months)
MoBo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
SDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442
CPU Cooling: Hyper 212
OS: Win 7 OEM 64bit
I know the build is a few months off but I like being prepared. Any suggestions or technology other than Ivy Bridge that will alter this build greatly?
around $1300
Kansas
CPU
MoBo
RAM
Case
HDD(SSD)
Cooling
to about 4.5
1440x900 sad I know
SLI would be nice
Nope
CASE: HAF 912
CPU: Ivy Bridge i5
OS: Win 7 OEM 64bit
