leSLIe
- Oct 18, 2004
I'm getting a new big radiator, and it will require lots of CFM. Lots of fans are not quiet, so I'm planning to put the radiator on the roof (one floor up from the PC)
I use flexible tubing, maybe will use a cooper pipe for the longest parts connected to this flexible tubing. Will use a D5 water pump
What is the longest, both in height and distance that you run your watercooling setup?
