Long time lurker, making my first overclock build.
Like many others I've put off making a new comp for 5 years now. I figured I'll use my winter break to build a new PC since grad school starts soon. I'd like to wait for the new Intel chips in Jan but I won't have time then as my break will end around the 14th.
I'm planning on overclocking for the first time so I won't be pushing the system too hard.
I should be ordering around next Friday/Monday.
So far I have currently,
Stacker 830 with a 750w PC&C silencerand 8 120mm fans that got tossed in for free by a friend.
A 22" Samsung monitor running 1680X1050
I'm looking to get the remaining parts with a $1200-1300 budget
CPU: Q6600
Cooler:Tuniq Tower- Eh, I've heard mixed things about the Tuniq tower fitting in the Stacker 830. Some say one of the fan holders simply needs removal, others say doesn't fit with the fan bracket at all. Still others say the door doesn't even close with the fan bracket removed.
Alternately I've been trying to find a Thermalright Ultima 90 from a trustworthy store as it might be a better fit and offer better performance.
Memory:G.Skill DDR2 1000 2gx4-8gb- From poking around various message boards it seems this memory is so/so for overclocking. Yeah 8gb is a bit much, but there's reasoning behind this..
1)I'm trying to slow the decay of my PC overtime
2)Virtual machines
3)Vista 64
Motherboard:Abit IP35 pro - Hearing good things about this mobo for its price range and ease of use for n00b overclockers like myself.
HDD:WD7500AAKS 750gb Caviar - The parallel recording 750gb version is on par with Raptors correct?
Any help is appreciated.
You can get the Ultima 90 from this great site here:
Thermalright Ultima-90 HSF - $46 & Panaflo FBA09A12M 92mm Fan - $3
Other than that, you're looking good. However do note that you don't even need DDR2-1000 to OC the Q6600 if you keep the FSB and RAM at a 1:1 raio. Here's what I mean:
Q6600:
Multi x FSB, RAM Speed = Clock Speed
9 x 266Mhz, DDR2 533 RAM = 2.4Ghz <== Stock Speeds
9 x 333Mhz, DDR2 667 RAM = 3.0Ghz <== Good OC
9 x 400Mhz, DDR2 800 RAM = 3.6Ghz <== Excellent OC
As you can see, all you need is DDR2 800 to get a pretty high OC out of the Q6600. Speaking of which, your Q6600 links to a 8800GT. Since OCing is in your plans, get the G0 stepping Q6600 instead since it runs cooler and can OC higher. Newegg does have G0 in stock but it's somewhat of a crapshoot. You can get the G0 stepping here:
Intel Core 2 Quad Q6600 G0 Stepping CPU - $277
Ahh sweet. Even though word has it Newegg has phased out their B3 Q6600 if I drop down my ram to DDR2-800 and and buy it off Clubit I save around $74. Thanks to you I might be able to afford purchasing it sometime next week.
Any comments on the processing/shipping time from Clubit and jab-tech?
I agree with Danny.
I'd still get it where its guaranteed. I havent tried them during holiday season, but during the year, they're both normal with ship time/order processing/customer service.
You mean perpendicular recording? I guess its on par... these are a few of my drives...
Avg Transfer Rate, Access Time: HDD info, Price
112MB/s, 13.2ms: RAID0 'cuda's, 600GB total, $120 (ICH9R on P35-DS3R)
78MB/s, 08.2ms: WD Raptor WD1500ADFD 150GB, $160
76MB/s, 13.7ms: WD Caviar SE16 WD7500AAKS 750GB, $150
72MB/s, 15.4ms: Seagate Barracuda 7200.10 ST3250410AS 250GB, $65
68MB/s, 13.3ms: Seagate Barracuda 7200.10 ST3320620AS 320GB, $60
65MB/s, 13.7ms: Seagate Barracuda 7200.10 ST3320620AS 320GB, $80
65MB/s, 13.2ms: Seagate Barracuda 7200.10 ST3300620AS 300GB, $60
63MB/s, 13.4ms: WD Caviar SE16 WD5000AAKS 500GB, $100
62MB/s, 15.3ms: Samsung HD501LJ 500GB, $105
52MB/s, 14.0ms: WD Caviar SE16 WD2500KS 250GB, $70
No 7200RPM drive can touch the raptors seek time, but I still don't think a few seconds is worth its higher price premium and lesser capacity.
Ah, now I understand the whole difference between the Raptor and the Caviar 750. Yeah seems more bang for buck on the Caviar.
Also on the Panaflo for the Ultima, I've been noticing that they are missing the third connection for the RPM sensor as they come in two versions. I've been trying to find a BX version with a high CFM without any luck. Or can I just use the fan without the RPM sensor?
No risk from the fan dying or etc?
Would an Sflex or Yate be better due to this?
You can use the fan without an RPM sensor with no problem. No risk of the fan dying or anything. According this review, the Panaflo performs about the same as an S-Flex. So no need to get the more expensive/bigger fans.
Yah, you'll be fine without it. Its hard to find one with an RPM sensor. :(
