LucklessCebu
- May 25, 2015
Got my L3 a week ago, put it together this weekend. Thoughts:
The case: is great! Exactly what I was looking for. Intel + GPU seems to make the most sense right now, but I figure if AMD actually gets their act together with Zen I might switch to an APU build a few years down the road and use the extra space for a pciE drive / case fan / whatever. Ended up with the following for hardware:
ASRock H81M-itx motherboard
Pentium G3258
Raijintek Pallas heatsink
Crucial Ballistix Sport 2x4GB DDR3 1600 kit
Crucial BX100 250GB SSD
MSI GTX 750 TI low profile card
Pico PSU 160xt
FSP150-AHB 150W adapter
Useful info for others:
-At least for this motherboard, the Raijintek Pallas fits the case quite well, albeit with extremely tight clearances. It's not quite as tall as the Cryorig R1, so it doesn't have the problem of being too close to the side of the case. You can only really mount it in one direction, though - facing down towards the graphics card. Could possibly mount facing towards the ram slots, but you'd have to modify the clip attaching the fan to the heatsink, as it will interfere with the edge of the case. Clearance as is: extremely close to the graphics card, barely clears the pico PSU. Clears RAM slots fine, so long as you have low profile memory. No real way to do any case work without taking off the heatsink first, though - ram, pico psu and graphics card are all stuck until you remove the obstruction. I don't see it mentioned much, but for those who want a reasonably powerful cooler without the clearance issues (and can afford it) the Noctua NH-L9x65 looks pretty solid. Making a cooler the same height as low profile cards is very smart.
-Haven't tweaked everything out yet, but the system is currently idling at about 26 watts at the wall. Could do 6-7 watts better without the graphics card, of course, but not too shabby all in all. I'd love to get my hands on an HDPlex and compare the efficiency with the pico PSU.
-The "4 pin mini DIN" connection as described by mini box is the same thing as what other sites describe as a "4 pin DIN" connection - just marketing confusion. Useful if you decide to splurge on getting a really nice adapter like the Meanwell GS220.
-The MSI card fans are quite obnoxious. Especially annoying because the Pallas is very quiet at lowish fan speeds. The rubbing noise others have mentioned seems to be present for me as well, but it doesn't ever go away. Tweaking the fan speed doesn't help - it's set to not go below 1/3 speed, and raising the speed makes it even more obnoxious. I got the refurb MSI from Amazon, for what it's worth. Debating whether to return the card, but it might be easier to just take off the fan and replace it with something like a Noctua. Any thoughts on whether I could just mount it to the edge of the case there, or would the old "zip tie to the heatsink" method work better? Might just have to try it out.
Pentium G3258
Pico PSU 160xt
