Logitech G930 Wireless Headset $80
nice headset. Decent battery life and a huge perk is being able to charge while listening - which is especially possible w/the crazy long cable they give you with it. My brother did snag a Corsair (?) headset that has better range, software and battery life, but no charging during use. Weigh out what's more important, I guess?
I got these on Amazon for $70 new during the Black Friday lead-up last year. Nice headset with only a few complaints. The battery life is not great, it's only 6-7 hours, maybe even less. You'll be disappointed to hear the warning noise in a heavy gaming or movie watching session, but as mentioned, you can charge it while it's in use with the microUSB cable.
It's pretty comfortable overall, but the faux leather earpads can get warm, especially on a hot day. I think the earpads with felt may be a little better for long periods of use. Overall great headsets though, the mic also works great for those who game online. Range is very good as well, maybe 60 feet through floors too.
If you live in an Apartment building or an area with a lot of wireless networks don't bother with this set. There is no way to change the channel on the unit, it uses 2.4 GHZ so everyone and there mother is occupying that frequency. You will get constant disconnects that last for 10-15 seconds. If you do a simple search of Google you will see the mass reported problem's that this unit has. I am a logitech proponent as I have a g400s, g5, g700, mk520, logitech mini dinovo, but this is a set I would not recommend.
i have never had any issues with my headset in apartment buildings. i have lived in 2 different buildings that were quite dense and never had an issue. the only consistent thing that seems to make me lose connection is wearing them on the other side of the refrigerator.
I had this same issue so I had to stop using them. It kept getting interference from my Wi-Fi router. Shame too, great pair of wireless cans for the price.
That is disappointing to hear. I was considering getting a pair of these.
I have a set and 2 N routers and no drop-outs. Great cans and after 2 years still good battery life.
I have them as well. Not a single problem.
If 4-6 hour battery life is short, I don't know what to tell you. They charge while using them.
if you are worried about interference, just buy them from someone with a good return policy. or, go buy them at best buy for full price, try them out, return them and buy them from link above.
myself and 4 other friends i know all use them and while they aren't perfect, none of us have found a better solution near the price point.
I have them, and I sit right next to my dual band router... no interference to speak of. But that's just an anectode so apply salt as you see best.
THat said, I like em a lot. They fit over my glasses earpieces without pressing them into my head, and the sound is pretty darn good.
The one complaint is that they have these great programmable buttons on the sides of the earcups. The problem is, they aren't universally programmable. So they only work with certain apps, and are generally useless. Small quibble, but there it is.
