Calis said:
ferrisnox said:I thought I would insert my 2 cents, having tried each mouse for 1 day initially. My previous mouse was a mx510 a pretty good mouse, but honestly not very comfortable for my wrist. First I tried the G5 the Grip texture was a huge improvement, the buttons aren't really slick like the mx510 and goo from your fingers dont accumulate. However why they didnt do this the fist time I dunno (slap engineer here) The tracking was excellent out of the box on the G5, however it had problems on dark mousing surfaces. The loss of a thumb button sucked for me I like my back and forward. While I like the scroll wheel side scrolling, I dont like it more than my ability to middle click. The adjustable weights were a joke for me...I don't need a heavy mouse, it already weights enough empty.
The copperhead fit my hand very differently, I was moving my hand with the mouse, not just the mouse hard to explain, but I experienced less wrist strain and a much better feel than the logitech. The texture was great, the buttons are rough and grooved for your fingures, and the blue piece that wraps around is a soft rubber. There is no side scrolling with the wheel, but it has a great middle click and positive notched feel. There are two thumb buttons easy to push unless you have short thumbs. If you look on other forums some people have been having problems updating their firmware for the copperhead. I will say this mine came with 6.13 and tech support emailed me 6.16b, I flashed with no problems and it took care of the negative acceleration. The tracking is also superb and mine doesnt have any problems on even dark surfaces.
For me I kept the Copperhead, and took the G5 back. The G5 is a good mouse, but its just not comfortable to me, and that is the most important. I'm very happy with my copperhead and I would recommend others to try it but follow Razer's guide for upgrading your firmware carefully.
Sir-Fragalot said:Upgrading your mouse's firmware is a crock. That's the most rediculous thing I have read on the forum to date. A mouse that needs a firmware update in order to track properly sounds like a piece of shit to me. I was thinking about trying a Copperhead until I read that.
That's my $0.02.
They're also ultra-uncomfortable. Frelling massive, and the buttons on the side are strangely difficult to reach. They really look nothing like that in real life.Sir-Fragalot said:Those have been around for awhile. They look really cool. Theres a leather covered wireless one too. I wish they'd make a leather covered Logitech G5. That would be sweet.
Soymilk said:i agree with ^^^. its like a driver update for your video card. im pretty sure you dont think everything nvidia and ati release are POS's cuz they have to update their drivers...
banGerprawN said:They're also ultra-uncomfortable. Frelling massive, and the buttons on the side are strangely difficult to reach. They really look nothing like that in real life.
Stopped giving them money at about the same time as the MX500 came out too, eh?Sir-Fragalot said:Agreed. I've used them before and didn't really like them. I also felt they were cheap feeling. Microsoft used to get my mouse money, but they haven't had a competetive product to Logitech in some time.
banGerprawN said:Stopped giving them money at about the same time as the MX500 came out too, eh?
And always thought Microsoft had a real cheap feel, except for this wireless keyboard that I still type on, because it's just really comfortable and all of the keys evenly depress. *shrugs*
ferrisnox said:Well before you dog a mouse for having firmware ask yourself why it has firmware, because it can save up to 5 different profiles on the mouses onboard memory, something that no other mouse ever made can do. Then you just plug it in, no drivers necessary and it will operate at whatever profile you want. And for the record
My mouse worked absolutely fine out of the box with 6.13, I only upgraded because I could. The negative acceleration problem is only present at 2000dpi with the sensitivity turned down as low as it would go. ..... which isnt a setting any non-retarted person would be using anyway. Ultimately I wasn't trying to sell you one way or the other just give my opinion since I have used both.
Sir-Fragalot said:I've just not found any of the recent MS mice to be that comfortable.
Strykar said:Indeed, I was very dissapointed with the 4.0s, we should petition to Microsoft for geek edition Explorer 3.0 or something![]()
Sir-Fragalot said:I really never liked alot of the Intellimouse Explorers. I always felt they were too large and I don't know about the later models, but the first ones cords would pull out too easily.
It's not just you. It's still the best mouse ever made IMHO. I can't figure out why MS discontinued it.Skin said:Is it just me, or is the IE3.0A the best mouse ever made? I have tried almost all of these new ones, and nothing can come close to my old one in comfort.
After this one dies, Im going to have a tough time finding a new one
Strykar said:That's not a 3.0, that's a 4.0
Strykar said:Or Alienware, ew..
Ah, I remember those. I bought one on some reccommendations for a decent cheap mouse (hey, I was unemployed and 14 years old, don't start with me!BBA said:I also gave away my IE3 from Q'con, it sucked in comparison to the A4Tech old tech mouse I still had. That was mostly because I move my hand way too quick for almost any sensor type mouse (except for the new gen MX and Lasers)...freakin turn too fast and I was looking straight down or up and not at the target.
Curve said:I never used that upper button on the left side anyway so it doesn't matter to me. Logitech all the way![]()
Indeed.Strykar said:I couldn't live without my 2 side buttons![]()
ajm786 said:Well believe it or not, a lot of people did, and that's one of the reasons why they're detracted from the G5. Me included.
Definitely the MX518. As far as I'm concerned, the sensitivity is spot on, it has 2 side buttons, a great feel, and no matter what anyone says, there IS lag in wireless!northrop said:My IE3.0 is dieing on me, I cant use the roller anymore, and the left click sometimes reacts as double or triple click which can be very irritating when working in PhotoShop. I went to my local BB, and I looked at the Copperhead and maybe it was just a bad display mouse, but I wasnt impressed by how it felt in my hand. The side buttons were a little awkward too. So now Im split between Logitech MX 1000 and MX 518. From the two, which one would you recommend? I dont want the G5/7 because I need my two side buttons (we have a regular two button mousse at school makes me wanna kill someone).
I also found this mouse on the MS site http://www.microsoft.com/hardware/mouseandkeyboard/productdetails.aspx?pid=049 but cant find it on sale anywhere.
Any suggestions are more then welcome. Thanks.
