Logisys Remote Control Wall Outlet (x2)
Northerner
Logisys Remote Control Wall Outlet (x2) $16.99
http://www.xoxide.com/logisys-remote-outlet-controller.html
Turn things on and off...electrical things...by remote! Lighting, computer equipment, audio-video equipment, blenders, the possibilities are as endless as the empty space between many people's ears. This is the Logisys Remote Control Dual Wall Outlet Kit!
xoxide_2029_356147981
Interesting. Would be handy for my Christmas lights. Although for $17 + ship I guess I can probably just run out in the cold.
I got a dual setup from the store for that price. Except it's indoor/outdoor rated with keychain fob remote. This is not so hot.
So, could I put this on my siblings computers and turn them off at will?
i got almost the same thing with 3 plugs for 15 bucks at Lowes this weekend. also if you get 2, it only has 3 buttons but they all have the same FQ so you can have as many as you want.
master I am not sure but what type of plugs are those?
http://www.dealextreme.com/details.dx/sku.13147
I got one of the cheap setups...remote and 3 plugs for $22 shipped. It works fine.
The only problem I have is it eats batteries. The little 12 volt looks like a short AA and they aint cheap.
I bet this one is better built....but that is just from the looks of the unit in the pics. I might be way off
hell I know I am off :)
Normal 110V plugs (there is a 220V version too); they just look a bit strange, I'm assuming because they were made to accommodate 220V plugs as well as normal, grounded 3-prong plugs. The plastic casing on the two versions is identical, probably to save on manufacturing costs. For $5 though, I'm not complaining. We'll see how they work once they arrive.
