Login\Pin\Help
ea6b123
Argggh i hate M$ and the damn login or pin or use a password to use MY computer crap!!!!!!!!!!!!!!!!!!!!!!!!
How do i login to windows with NO pin or password please. It some how made 2 accounts and one wont login and dont know how to remove either to login and with NO pin or Password, Thanks !
Win 10 Pro 64 bit latest build
You seem really mad. Let's calm down and look this through.
On a fresh install of Windows 10, on Pro at least, if you don't want your account to have a password, create a local account, and for the password, put.. no password. Just hit Next.
If you have a PIN, it's very possible you set up a Microsoft account and since that's a secured resource, MS will expect that to be behind a password/PIN or other Windows Hello thing.
I didnt have a choice it asked me to setup a pin to continue otherwise i couldnt continue the install. I wish MS would make this an *option* when you install
did you sign in with an ms account? thats the only time it will prompt for a pin and that can be cleared via you account page on their websites, i think.
If you use a Home edition of Windows 11, and frequently on Windows 10, the initial setup will only give the option for a Microsoft Account to sign in. As an online account, it requires security.
If you do not understand which edition of Windows you have, you may need to refer to your PC documentation.
