Rebooted my computer the other day and it locked up on "Checking NVRAM". I checked the SOYO website for support and it's listed 3 possiblities.
1. An IDE device might be faulty
2. Your power supply may be defective
3. Your boot priority may not be set correctly
I've disconnected the only two IDE devices in the system (CDROM & a hot-swap HDD bay), tried booting with a different PS and double-check to make sure theres nothing screwy with my boot priority. I even changed the boot sequence around a couple different ways but no luck.
So last night I take the battery off the motherboard to reset the motherboard, but before I disconnect power and short the jumpers, I try to boot the system up. It worked fine. Power down, put the battery back in, and now it's stuck at "Checking NVRAM" again.
Could this be as simple as the battery is dying?
