Locking eSATA cable?
Discussion in 'SSDs & Data Storage' started by kumquat, Mar 16, 2014.
  1. kumquat
    kumquat [H]ardness Supreme
    5,269
    Dec 7, 2005
    I've been looking around for a while and can't find any eSATA cables that have a latch or lock similar to what's now common on SATA cables.
    Does such a thing exist? Do most devices with eSATA ports support them? Where can I find one?
  2. Old Hippie
    Old Hippie [H]ardness Supreme
    6,013
    Oct 31, 2005
  3. cortexodus
    cortexodus [H]ard|Gawd
    1,614
    Feb 20, 2009
    Funnily enough, your GIS for "lockable esata cable" shows almost nothing but SATA cables. ;)
    In any case, a search on Amazon for "esata latch" finds plenty of what OP is after. ;)
  4. kumquat
    5,269
    Dec 7, 2005
    I see a lot of latching SATA to nonlatching ESATA cables there. There's one 6 ft cable that says "metal latch" but nothing in the picture of the connectors looks at all like a latch.
  5. SirMaster
    SirMaster 2[H]4U
    2,122
    Nov 8, 2010
  6. cortexodus
    1,614
    Feb 20, 2009
    touché :) I guess eSata with a locking head isn't particularly common.
  7. SirMaster
    SirMaster 2[H]4U
    2,122
    Nov 8, 2010
    I mean, eSATA connectors kind of do have a metal part that "hooks in" when connected that provides extra resistance compared to a plain SATA connector's completely smooth construction.
    Pretty sure that's all there is for eSATA. You would have to find a cable with a real latch and also a female plug on a device that accepted that same latch.
  8. kumquat
    5,269
    Dec 7, 2005
    That's a shame. I've used eSATA for removable storage before, but mostly backup drives and whatnot. Now I'm using it for full-time work and was hoping for something a little more robust. Oh well.
    Thanks.
  9. Old Hippie
    6,013
    Oct 31, 2005
    Yikes, what a mess!
    Looks like we have type "I" and type "L" SATA external connectors along with eSATA.
    Check out some pics here.
    No locks on any eSATA.
  10. cortexodus
    1,614
    Feb 20, 2009
    This is actually a really helpful page, thanks! :cool:
  11. patrickdk
    patrickdk Gawd
    744
    Jan 3, 2012
    Well, it's really not that much of a mess.
    SATA L is normal internal sata connectors.
    SATA I is ESATA.
    But cause esata didn't come on many things, everyone started making sata to esata adapters, causing that mess you see, and the mixup of terms.
    What is more fun, is power over esata, or otherwise known as, esata+usb on the same plug.
