To play dota 2 and web browsing
I would like to spend 500 or under but slightly over wouldnʻt be the end of the world. I live by the newegg warehouse so i will do will call.
USA orange county.
Case, Ram, MOBO, GPU, PSU, Optical, Hard drive, CPU. I will list what i have put together below.
No reuse as of now i may take a hard drive out of an old lap top.
6) Will you be overclocking?
No
7) 7) What is the max resolution of your monitor? What size is it?
I am in the market for a monitor budget is separate from the computer would like to spend 100 or under on a monitor.
Just under two weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB, SATA 6gb/s,
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Windows 7 64 bit
Here is the list of components i have put together on newegg. This will be my first build so any advice would be well appreciated. I am also very unsure of my PSU. Thanks!
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM $19.99
Fractal Design Core 1000 Micro ATX Computer Case w/ 1 x 120mm fan $39.99
Seagate Barracuda ST500DM002 500GB 7200 RPM SATA 6.0Gb/s 3.5" $59.99
GIGABYTE GA-78LMT-USB3 AM3+ AMD 760G USB 3.0 HDMI Micro ATX AMD Motherboard $64.99
SAPPHIRE 100358L Radeon HD 7770 GHz Edition 1GB 128-bit GDDR5 PCI Express 3.0 x16 CrossFireX Support Video Card $114.99
Antec NEO ECO 400C 400W Continuous Power ATX12V 2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply $39.99
G.SKILL Value Series 4GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model F3-10600CL9S-4GBNT X2 $47.98
($23.99 each)
AMD Athlon II X4 640 Propus 3.0GHz Socket AM3 95W Quad-Core Desktop Processor ADX640WFGMBOX $79.99
USA orange county.
No
USB, SATA 6gb/s,
Windows 7 64 bit
($23.99 each)
