racebanner said:Correct me if I am wrong but a tank (actually a dewars) of liquid nitrogen contains liquid which boils at -320 F. The tank feels warm due to the vacume between the inner cold as hell walls and the outer ambient temp walls. I have never heard of compressed "liquid" nitrogen. The pressure in a dewars is directly related to the temp of the liquid inside which if you had a dewars full of liquid nitrogen and brought it to a normal ambient of say 70F you would have an extremely high pressure, so high it would blow a dewars apart.
Blethrow said:It's not compressed (well barely, maybe a few PSI depending on the container), and it's not at room temperature. It's extremely cold. The dewar is vented and some LN2 is constantly boiling off; this takes away the heat that slowly makes it's way into the dewar. I work with this stuff all the time, mostly for cryo storage of cell lines, and I can assure you it is in fact quite cold in the dewar.![]()
derrick45123 said:I remeber seeing this thread awhile back and I was just browsing YOUTUBE and found this video http://www.youtube.com/watch?v=OdPOeM2XHts&search=computer modding, I know nothing of this but I found this video and figure it could be of some assistance.
Serge84 said:Liquid nitrogen should not be taken lightly. Touch it, and you lose a finger. Poor it wrong and you can kiss the mobo and floor good bye. Liquid Nitrogen exposed to air and released in its liquid state will make fast work of super freezing anything and turn it into very brittle parts. Most normal matter will shatter when this stuff touches it. Its so cold it would shatter a person like a bullet to glass in only a moment.
You need special containment and tubes. NASA grade crap. Its just suiside to even use it as a coolent for even a insane person. lol Its too extreme for me unless I was in a sub-zero hazmad suit. I wouldn't get near that stuff. That maybe alittle much for the chip. Your slowing down those atom's quite abit. Your prob slowing down the chip itself. Liquid nitrogen is close to absolute zero by only about -100C or -200C you know.
Cpt.Planet said:In order to get Nitrogen into a liquid form it has been compressed similar to dry ice being compressed. They start off with air compress it and cool it and viola liquid nitrogen. Dewars are made to let some of the nitrogen boil off. They are not 100% sealed.
blue_dragon said:all matter is made of atoms and molecules
as most people know a liquid is more compact or squished than a gas
when you compress a gas your literraly squishing it into a liquid![]()
HOCP4ME said:That depends on how much you compress it.
But I remember now, here's how LN2 is made:
1. The gas is put under pressure by huge compressors. No doubt it turns to liquid under the pressure, but it's still at room temp.
2. The gas is allowed to expand through special nozzles that relieve the pressure very, very quickly. This rapid drop in pressure forces the liquid to evaporate.
3. As the liquid evaporates, the surrounding temp drops rapidly. It eventually drops low enough that N2 condenses at 1 bar.
4. The LN2 is collected and stored in the dewer. You now have very cold, unpressurized LN2.
So, it is cold, and it is not under pressure, but pressure is used to condense it.
fixed. compressing something and then just letting off the pressure won't do crap, gotta remove that heat somehowHOCP4ME said:1. The gas is put under pressure by huge compressors. No doubt it turns to liquid under the pressure, but it's cooled or chilled to remain at or below room temp.
(cf)Eclipse said:fixed. compressing something and then just letting off the pressure won't do crap, gotta remove that heat somehow![]()
-(Xyphox)- said:as i read this, i am thinking if you need Liquid Nitrogen to cool your rig you have some problems... LoLThat is some MAJOR OverClocking
So you're saying if LN was put in a sealed heatpip located on a cpu heatsink which was in action (cpu getting hot), the LN would not cool the cpu at all because there is no air in the heatpipe and the LN cannot evaporate?jinu117 said:Liquid nitrogen... yes... well... let me explain a bit... it will be lengthy reading...
When you get tank of liquid nitrogen... is it cold? No.
Compressed liquid nitrogen isn't cold at all... it is just at the ambient temperature.
It does get cold when it evaporates. This is basic refrigeration concept really.
There are something called heat of vaporization, sublimation, etc when phase of matter (solid<->liquid<->gas) changes. In case of vaporization, it takes enermous heat to happen or absorbs heat. Liquid nitrogen itself is not cold. It is cold when it evaporates.
Critical temperature comes into question which is where liquid nitrogen will evaporates at atmopsheric pressure which is well below being "cold". - this temperature can change based on pressure it is under.
You see, LN pot works since all you do is pour it into the pot, and since temperature is well above critical temperature, it "boils" off absorbing heat around.
For to have loop for it involves actual refrigeration unit.
And in case of refrigeration unit, due to characterstics of it, you need to have 4 stage cascade at least or 5 stages... or autocascade with similar stages. Not cheap or quiet or easy to operate by any mean.
So simple answer... NO...
Possible with proper refrigeration loop... YES... (or else how do they make this liquid nitrogen)
Hope this was clear enough for you.
alik4041 said:So you're saying if LN was put in a sealed heatpip located on a cpu heatsink which was in action (cpu getting hot), the LN would not cool the cpu at all because there is no air in the heatpipe and the LN cannot evaporate?
Oh, I know. I'm here to learnStuey83 said:Disclaimer: I know what I'm doing and accept the risks. Do NOT try what I just described, as you can and probably will get injured.
alik4041 said:Oh, I know. I'm here to learn![]()
lol I know what you meant, but i'm still here to learn hahaStuey83 said:Nono, I meant the disclaimer so that nobody goes and sticks their hand into liquid nitrogen. I really don't need anybody losing a finger and then pointing at me while talking to their lawyer saying "he told me it was alright!".
But I also kinda meant it toungue in cheek. I've injured myself with liq N before. It's not pleasant. When I worked in the lab, we were told to not do the "dip the hand" thing because some undergrad lab instructors weren't telling their students that it was hazardous. One of the students told the lab coordinator that he could dip his hand under liquid N and it'd be alright.
But yea... liq N2 is highly volatile, but fun to play with.
HOCP4ME said:... as LHe is so cold, it causes a semiconducter to lose the "semi" part, switching all transistors the the "on" state.
qtwre said:Here's a question... What is the last element that would freeze at absolute zero?
