Liquid MetalPad thermal Interface pad, good?
yes its good for what it is. however if you put too much on, could be bye bye cpu(into socket=sparks).
its also meant to be difficult to remove. stick with AS5 or Ceramique, I also pondered your Q and decided not to and believe there isnt much I wont try. ;)
Thanks guys! Forgot to check back here lol.
Guess ill stay with the thermal compund and not the metal thingy.
i wasted $20 on a syringe of this and $220 on a brand new motherboard that it destroyed. i know many people use it with success but its up to you if you think 1-2C drop in temp (vs. AS5) is worth the chance in throwing away expensive components because of a fuckup. i will never buy it again.
