Hi folks. Discovered a leak from my CPU block that was dripping down onto my video card one day when I couldn't get anything to display. I felt the card, it wasn't even warm (usually scalding hot). I shut down the rig and removed the card. I put in another video card and the rig booted up and displayed to my monitor normally.
I removed that backup card and saw liquid was the strip where it plugs into my PCI-E slot, then realized that the slot itself had got liquid in it as well. I carefully cleaned my backup video card and the PCI-E slot and then re-inserted my backup card.
Now nothing, didn't even turn on. There is also a high pitched whine even when NO video card is plugged into the PCI-E slot. I can't tell if the whine is coming from my PSU or Mobo. When I jiggle the the 24pin ATX connector the whine changes frequency and stops upon removal of the 24pin. Tried a different power supply that I know works and the computer would still not turn on, although there was no whine either.
Trying to figure out whether or not my motherboard is toast as well as my video card, right now it looks like yes. Wondering if anyone has any experience with this kind of issue, knows about this high-pitched whine I'm getting, or has any other ways to assess the extent of the damage.
Thanks for any help guys.
