the absolute minimun is i5 2500k OC to like 4.6 ....Is there a guide to run those big work units in a linux VM? do you need a certain CPU? I have a Xeon X3440 on my ESXi host i might run while I am not using the host for other stuff.
How much PPD could I get?
Is there a new VM trick that I am unaware of?
you can tell *nix there are more threads than you have......it is frowned upon
Oh man, here we go again...
To answer the OP; yes there is a guide. Yes, you need a certain CPU or multi-proc systems which meet the 12 thread minimum. No, that CPU shouldn't do large WU's. Your PPD for SMP WU's should be around 30,000.
How do you get a VM to use the cpu properly?
FWIW, I wouldn't even try bigbeta with that proc. If you had a 2600K, maybe. You can run normal bigadv with it without issue, though. Another thing to consider is, does the box need resources available for actual use? If so, sucking up all 8 threads may not be a great idea. I assume ESXi lets you prioritize VMs, but I don't know enough about it.
but it works...![]()
Is that proc going to cut it on some of the chewy (aka 2684) WU?
If the system is doing much of anything else I'm not sure if you will hit the deadlines on all the -bigadv
I remember years ago there was a folding boot CD. .
So just run the regular smp client in a vm? just a normal 1 vCPU setup?
Is this the current guide http://hardforum.com/showthread.php?t=1511766
Now i just need to figure out the vCPU thing?![]()
