- Dec 17, 2007
Sigh
go away, go bug someone else's thread that you dont have helpful advice for.
Sigh
Actually, I quite agree that at some point, digging into it is the best way to learn, but we all have our own point where we're ready to do that. Making sure you have all the information first isn't a bad idea. I'm doing the same thing myself, but on a spare computer, so I have the luxury to jump in with both feet and not worry about screwing the system up...![]()
Don't assume what I 'don't get'.
EXACTLY, they dont get it. I agree that you need to jump in at some point. But im not at the point of having it installed and up and running and messing around with settings. I am before that point, figuring out how to install it without messing up my computer. I dont have the luxury you have (a spare computer) at least not yet. So im being as careful as possible, double checking everything.
Sure, that'd work great.
I just scanned over the thread and I'm still stumped as to why the OP (who is active and just made the post above) hasn't just done a USB stick installation and... well, why is that such a tough thing?
Download Unetbootin.
Download the latest Ubuntu 10.04 ISO from this page:
http://mirror.anl.gov/pub/ubuntu-iso/CDs-Ubuntu/lucid/
Get the "PC (Intel x86) desktop CD" ISO.
Once both are downloaded, find a USB stick at least 1GB in size (everybody has at least one of these, right? Right?) and put it in a USB port someplace on the machine, quick format it with FAT32.
Run Unetbootin, select the Diskimage radio button (it's a round check circle, not really a check box), then click browse (the button with ... on it) and browse to find the Ubuntu 10.04 ISO), select it, click OK, then change the Drive: to the drive letter of the USB stick, click OK and wait for it to make the stick.
When done, don't reboot (choose the appropriate option) then when you're ready to actually ready to test this and use Ubuntu on that hardware without touching anything on the hard drive at all meaning you can't and won't do any damage to your hard drive and your current Windows installation, reboot the machine off that USB stick.
Voila, done. Running Ubuntu, quick and easy. If it takes you longer than 5 minutes to do this (after the files are downloaded) then something is very wrong and you're going to need more help than this or any other forum can possibly offer.
I keep seeing fairly knowledgeable people offering you very similar information all through the 3 pages of this thread so far (I use 40 posts per page) and, I don't see the OP actually putting any of it into action. It's just "Oh, right, that's nice, ok someone else tell me this again... ok, that's what the other guy said, you're dismissed, someone else repeat it to me yet again for the umpteenth time... oh, ok, that's new but, still the same old thing the other folks have said, next person please..."
Just do it.
Edit: Btw, i have a 64 bit CPU , and am running Windows 7 64 bit. Can i use the Ubuntu 64bit instead of the x86?
Well, your best bet is to focus strictly on learning how to get things done on Linux/Ubuntu and stop focusing on the GUI and how it looks. You need to realize that any changes you're making: updates, patches, drivers, anything you do when you boot off that LiveCD or USB stick disappear forever when you shut the computer down.
Yes there is a way to make some data persistent so it is called up after a reboot but it's not something that I will get into and it's more complicated so... (forget I even mentioned it, now)
Linux like all OSes require drivers to communicate with the hardware, and some hardware just isn't supported worth shit, there's nothing you can do about it. Almost 100% of the onboard NICs (the wired connection) ever made are natively supported; probably only 80% of the wireless NIC (the wireless connection) are supported, most notably a lot of the Broadcom wireless cards/chipsets, those are just nightmares and again, entirely too complex to get into at this point.
http://ubuntuforums.org is the best place for you right now, seriously - I'm not going to argue it or debate it, this is a tech forum and even with this subforum for Linux support, that is your destination and should be your "home away from your Windows home" from now on. The information you want is over there at that forum, seriously. Sign up and get to searching for answers or posting questions, etc.
Until you commit to a hard drive based installation - which is EASY to do with Wubi as stated earlier in this very thread by several people - you're going to lose all the settings and adjustments you make when you run Ubuntu off that CD.
So use the LiveCD for playing around - because by playing around you learn stuff, and you can't really bust anything since you can just reboot and wham, it's all fresh and new again, as many times as you want.
Wubi can be installed in a few minutes, it doesn't touch Windows at all (just adds a line to your boot loader, it does NOT install GRUB by default, another topic I won't get into), and it's a true hard drive based installation (from the perspective that your changes and alterations will "stick" between reboots.
Linux diehards will say it's not a true hard drive installation and technically they are correct - it's not an actual bare metal install on the native partitions - it's more than acceptable for this purpose.
Where you go from here is up to you... and don't call me Neo.![]()
Best bet (my opinion here) is to install Windows 7 as the primary OS - that is what you're most familiar with assuming you've been using Windows for a few years or whatever. Obviously you're new to Linux/Ubuntu so I do not recommend it being installed as your primary OS.
If you do build a new machine, you can easily set up a dual boot (a real one with the real GRUB boot loader working with the Windows 7 one) but, Wubi will do just fine for you for a long long time to come, seriously. When you reboot the computer and you boot into Ubuntu, you ARE running Linux at that point, and there's nothing weird about it. The fact that Ubuntu is installed on a drive that normally has Windows on it doesn't matter at all.
Not sure why you're focusing so much on an SSD - I do realize they're faster but, they're not really cost effective just yet. A big fast hard drive is still the best way to get things done at this point.
That's my suggestion: stick with a big drive or two, use the money for something else, and continuing using Wubi until you have learned enough to be able to honestly say to yourself "Ok, time to install this the right way and leave Wubi behind."
That's a long ways off from where you are right this moment.
You can do all this from the CD, too, you know.
The USB option is recommended simply for one reason: it's faster, but not by leaps and bounds and everything in between. It's faster because USB sticks have faster random access times, as well as (for the most part) faster sequential read speeds even for random data. CD/DVD optical drives are notoriously slow when it comes to reading a lot of small files at random locations on a piece of optical media.
If you already have the 32 bit version of Ubuntu 10.04 burned on a CD that you created (or the 64 bit version one as well or inclusive), you don't need to go buy a USB stick.
In fact, because the ISO is already burned to a CD you're doing even better because with the USB stick you do have the potential of making some change to the OS files on that stick which could render it - meaning the Ubuntu OS on the stick - dead in the water. Even if Ubuntu is running from a USB stick it can and does still have the potential to write data back to the stick if done properly, aka root level process behavior, some errant command, that sort of thing.
With the CD you have no such issues - it mounts your Windows hard drive(s) as read-only by default, and the CD itself since it's already burned can't be changed in any way.
Save yourself the trip to the store:
Boot off the Ubuntu 10.04 32 bit CD and get busy with your Linux education.
That's about it.
1) It's something to do with your mobo and the BIOS settings, and not Ubuntu or the USB stick. If you used Unetbootin and it told you the creation of the stick was successful, it was successful. It's now a matter of figuring out how to specifically get that machine to boot off that USB stick. A lot of mobos offer an option of pressing either F8, F9, F10, and sometimes F12 to force a boot menu to appear and list all the available bootable drives attached: it'll list the hard drive configured for boot in the BIOS, it'll list optical drives (even if they don't have discs in them), and it'll list USB media if they are attached.
Try those keys or look in your mobo manual and find the one that forces the boot menu to appear and give that a shot. I have yet to see a mobo made since 2003 that doesn't offer this option so, it's in there someplace, you just have to find it.
2) That's horseshit, plain and simple. You can crush a USB stick by sitting on it in your pocket just as easily as you can scratch or break a CD or DVD. Neither one offers anything truly superior over the other except a USB stick's incredibly low random access times and somewhat faster transfers. Either one will work just fine for your purposes. Some laptops on the market don't have optical drives (Netbooks and some others) so, the USB stick option is there for that reason + convenience. They're easier to move around and carry than an optical disc which needs to be covered/wrapped in some way to prevent scratches and obviously kept relatively flat to prevent shattering, etc.
3) I just said that at the end of 2) above.![]()
