Did you use the -SMP flag. Without that on my dual core it doesn't max things out (Ubuntu 8.04).
Xilikon said:While I have experience with Linux folding, I never tried running 2 SMP together because I'm running VMWare so each instance get 1 SMP client and each box get 2 VM instances to maximize the production.
http://www.hardforum.com/showthread.php?t=1265008&highlight=vmwareSince I've got a second q6600 (arrived yesterday, rebuilding this weekend) I'm looking into running dual VM's... Any good guides for setting that up? What do people use for affinity management in XP? If there are good guides out there feel free to point me to them.
If you have the machine overclocked to at least 3.2 I would suggest running 2 SMP clients natively for ease of use. Anything slower than that and it might not make deadlines on some of the work units which is bad. I've almost had this happen with my machine at 3.6. As stated previously, some work units are horrible about scaling up to 4 cores which wastes a LOT of CPU cycles. Running dual clients when crunching these work units doesn't help out the PPD a whole lot, it is noticeable. Even with dual clients crunching on the chewy work units, my cores usually don't go much higher than 80% utilization on each core. I'm afraid there isn't much which can be done about that at this point. Most likely we'll just have to wait for the A2 core to be released to an open beta or something which should do much better with scaling with more than 2 cores.
If this doesn't make sense, well I'm a rambling man at times. Just say something and I'll attempt to use drunken English which would probably be easier to understand.
