Hi
Im new here, don't really post on forums much anymore but recently I built myself a file server using old bits and a few new bits..
Also let me begin by saying im quite new to linux so could be a big error on my half.
For those who care this is what it looks like
Now the major problem with this is the speed of the file transfers im getting. Im storing some Hd movies to stream to my HTPC and need to be getting some reasonable speeds for smooth playback.
Spec of file server
CPU - AMD XP 2000+
RAM - 2x 1GB PC3200 DDR
Motherboard - Asus A7N266-VM
PSU - Tagan TG480-U01
System HDD - Seagate 2.5" IDE 4200rpm 80GB
Network - Gigabit Dlink DGE-510T
SATA Card - SATA PCI Sil3114 (was a reasonably cheap one off ebay)
Storage Drive - Western Digital Green Power 1TB
OS - Ubuntu 8.04
Installed Apps - Webmin, Samba, SSH, Azureus
So personally I think this system should be able to reach more than the slow speeds im getting.
Here are some of my file transfer tests between the 3 computers on my gigabit network at the moment.
So this just about shows that my HDD isnt the problem.
Testing the network I used iperf
This is from the terminal of the server
Last few bits show, 4 - laptop speeds, 5 - htpc speeds
Not quite sure why the laptop is slower.
hdparm results of the 1tb drive.
Can anyone help me on this? Really don't know where to go about sorting this problem now.
Really could do with the speeds between the laptop and htpc on my server.
Any help would be appreciated.
Spec of file server
CPU - AMD XP 2000+
OS - Ubuntu 8.04
Code:
Laptop to HTPC - 23MB/s
HTPC to Laptp - 25MB/s (does hit 35MB/s at times!)
Laptop to Server - 10MB/s
Server to Laptop - 8MB/s
Some tests to the system drive of the server IDE 2.5" 4200rpm 80GB
Laptop to Server - 13MB/s
HTPC to Server - 9MB/s
Server to HTPC - - 8MB/s
Following is with HDD mounted in a SATA USB Caddy to laptop
HDD to Laptop - 25MB/s
Laptop to HDD - 36MB/s
Code:
root@nas:~# iperf -c 192.168.1.5
Client connecting to 192.168.1.5, TCP port 5001
TCP window size: 16.0 KByte (default)
[ 3] local 192.168.1.6 port 39982 connected with 192.168.1.5 port 5001
[ 3] 0.0-10.0 sec 84.8 MBytes 71.2 Mbits/sec
root@nas:~# iperf -s
Server listening on TCP port 5001
TCP window size: 85.3 KByte (default)
[ 4] local 192.168.1.6 port 5001 connected with 192.168.1.5 port 50421
[ 4] 0.0-10.0 sec 156 MBytes 131 Mbits/sec
[ 5] local 192.168.1.6 port 5001 connected with 192.168.1.8 port 49268
[ 5] 0.0-10.0 sec 430 MBytes 360 Mbits/sec
Code:
root@nas:~# hdparm -Tt /dev/sda1
/dev/sda1:
Timing cached reads: 472 MB in 2.00 seconds = 235.44 MB/sec
Timing buffered disk reads: 216 MB in 3.02 seconds = 71.48 MB/sec
root@nas:~#
