Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I added the x-swat ppa, but I can't download the package correctly. I'm typing in the syntax wrong. Don't I need to run the purge command to remove the existing driver? I'm going to install 12.04 over 13.10 after work.
